Socket.io server on .lp file
is there a possibility to use socket.io in .lp file to create realtime and simple connection with client without a http requests?
Done is better than perfect
Please explain your taks a bit more. Anyway, LuaSocket should never be used in .lp because it will block the whole webserver during i/o operations. You should use these functions instead: https://github.com/openresty/lua-nginx-m...xsockettcp
Recently I've created a nodejs app for realtime controlling inverter in one project. It had a client and a server and all data was exchanged via websockets in two directions. Thanks to websocket it was possible because like in LM with localbus. But in this project I've noticed that this technology could simplify and improve also other communication between client and server what's normally is done by http requests and exchanging data in JSON file.
I think websockets would be useful in .lp files for:
- every client show up-to-date app state (server sends every change in config to all clients without need to refresh page by client). This also removes the need for polling some data.
- server could send something to connected clients.
- generally I think that such possiblity could help to create better and more advanced apps to LM
Another question I have:
- could you replace jQuery need from localbus?
.lp can already work as WebSocket server. Here's a short example:
<? local json = require('json') local ws, err = require('ngx.ws'):new({ timeout = 10 * 1000 }) -- websocket init error if not ws then   write('websocket init failed: ', tostring(err))   return end request.raw = true local lb = require('localbus') local function lbthread(ws)   local client = lb.new()   local run = true   -- telegram event   local function groupcallback(event)     event.tsec, event.tusec = os.microtime()     local data = json.encode(event)     if not ws:send_text(data) then       run = false     end   end   -- set callbacks   client:sethandler('groupwrite', groupcallback)   client:sethandler('groupresponse', groupcallback)   while run do     client:step()   end end local function datacallback(data)   -- ignore ping messages   if data == 'ping' then     return   end   data = json.pdecode(data) end local co = ngx.thread.spawn(lbthread, ws) repeat   local data, typ, err = ws:recv_frame()   if typ == 'text' then     datacallback(data)   end until ws.fatal or typ == 'close' or ngx.worker.exiting() ngx.thread.kill(co) if not ws.fatal then   ws:send_close() end
jQuery is required for localbus, but only $.ajax, $.param and $.each functions are used. I suppose you can provide your own compatibility layer if using any other JS library.
Thanks admin, it is helpful. What is the websocket server path in this example (I must type it on client script)?
As for any other .lp, just replace http:// with ws://
I try understand this and not only do this. So if in .lp file there would be 2 websockets defined then they would using same address?
Why two websockets? There's one localbus socket which is local UDP broadcast, another one is server-client TCP connection.
(18.12.2018, 16:57)admin Wrote: Why two websockets? There's one localbus socket which is local UDP broadcast, another one is server-client TCP connection.
This was only theoretically question. I don't understand where in attached code there is the websocket assignment to some port. Because in a few examples which I read always there was some address + port 8080 (probably default for websocket);
Like below:
local ev = require'ev' -- create a copas webserver and start listening local server = require'websocket'.server.ev.listen {  -- listen on port 8080  port = 8080,  -- the protocols field holds  --   key: protocol name  --   value: callback on new connection  protocols = {    -- this callback is called, whenever a new client connects.    -- ws is a new websocket instance    echo = function(ws)      ws:on_message(function(ws,message)          ws:send(message)        end)      -- this is optional      ws:on_close(function()          ws:close()        end)    end  } } -- use the lua-ev loop ev.Loop.default:loop()
You don't need a separate port, websockets is just an extension over standard http requests.
Thank you very much for your admin for help, I will test it.
