Internet Explorer 11 and rounding boxes issue
Do you know a trick how to get out these strange borders around any SVG object?
The only browser I've met this problem is an obsolete IE11 and actually dying Edge. But unfortunately I need to use it.
Try Right click > Inspect element and see if it has a border in Computed tab.
I see nothing special here. I'm afraid there's something missing instead of wrong.
Simply wow
https://developer.microsoft.com/en-us/mi...s/7340561/
And the winning workaround is to use iframe (Frame in LM Visu Designer) and path to SVG picture instead of "picture".
This can be fixed differently, wait for Monday Wink
Add this to Custom JavaScript:
$(function(){   $('object').each(function(index, el) {     var obj = $(el);          obj.clone().appendTo(obj.parent());     obj.remove();   }); });
Hi Admin
Thank you.
But what is the performance impact of this solution? I'm not sure if I understand what this script does. Does it simply copy all objects and then destroys the original object? Which means 1000+ objects in my case?
This only affects SVGs that are placed as image elements, not object icons. And yes, it creates a copy and removes original element.
