I'm trying prepare some solution but I've have some strange problem in one script. I am trying fill the 'responseType' property in state variable but it is not working.
And this is from Logs:
It looks like in this table it is not possible to add responseType property because it is not visible. Or I cannot type property with a capital letter. It is strange because in cmd table I am using such property so it should be possible.
Also such situation is very strange:
Logs:
Yesterday I've received this LM and it has firmware 20180523. So maybe this is the case?
Aha, it looks that when in the table there is some binary/hex value then log() function can cause some strange behaviours because when I've changed data to some simple string print is appropriate.
local responseType = cmd.responseType
log('responseType', responseType)
local state = {value = responseType, responseType = responseType, data = data}
log('state', state)
table.insert(states, state)
Test 15.08.2018 17:46:04
* arg: 1
* string: responseType
* arg: 2
* string: outputsState
* arg: 1
* string: state
* arg: 2
* table:
[value]
[data]
* string: ��
* arg: 1
* arg: 2
* string: inputsState
* arg: 1
* string: state
* arg: 2
* table:
[value]
[data]
* string: ��
local states = satel:getStates()
log(states[1], states[2])
log(states[2])
Logs:
Test 15.08.2018 18:11:56
* arg: 1
* table:
[name]
[data]
* string: ��
* table:
[name]
[data]
* string: ��
Done is better than perfect
