Threads: 48
I'm trying to push data up to Azure IoT Hub and having some difficulties with the examples I've found on the forum and openrb.com so far.
Does anyone have an example for connecting to Azure IoT Hub with MQTT?
Threads: 48
So no-one has successfully managed a connection towards Azure IoT Hub with LM/SL via MQTT?
I've tried this:
http://openrb.com/mqtt-client/#codesyntax_1
But it doesn't give me any feedback what's wrong, nothing in error log. I'm also doubting it's running at all, as log in between code that should be executed doesn't give results. In Microsofts cloud there are no indications of a connection.
Threads: 43
Can you send client id, MQTT username and password via PM? Info on username/password format:
https://docs.microsoft.com/en-us/azure/i...tt-support
Threads: 48
Threads: 43
Thanks!
First, you need to update MQTT library packages:
New CPU:
https://dl.openrb.com/pkg/libmosquitto_1...1_imx6.ipk
https://dl.openrb.com/pkg/luamosquitto_0.3-2_imx6.ipk
Old CPU:
https://dl.openrb.com/pkg/libmosquitto_1.4.15-1_mxs.ipk
https://dl.openrb.com/pkg/luamosquitto_0.3-2_mxs.ipk
Here's a minimal example that you can use, don't forget to change device_id, broker, username and password parameters. You also need to upload azure.crt via FTP (using ftp username, upload to root directory). Certificate file contents:
https://gist.github.com/jsopenrb/5873b20...d6b950151f
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
device_id =
'DEV_TEST'
broker =
'DEV.azure-devices.net'
port =
8883
username =
'DEV.azure-devices.net/DEV_TEST'
password =
'SharedAccessSignature ...'
mqtt =
require (
'mosquitto' )
client =
mqtt.new (
device_id )
client.ON_CONNECT =
function (...)
log (
'ON_CONNECT' , ...)
client :
publish (
'devices/' ..
device_id ..
'/messages/events/' ,
'{id=456}' )
client.ON_PUBLISH =
function (...)
log (
'ON_PUBLISH' , ...)
client.ON_LOG =
function (...)
log (
'ON_LOG' , ...)
client.ON_DISCONNECT =
function (...)
log (
'ON_DISCONNECT' , ...)
client :
version_set (
mqtt.PROTOCOL_V311 )
client :
tls_set (
'/home/ftp/azure.crt' )
client :
login_set (
username ,
password )
client :
connect (
broker ,
port )
while true do
res ,
err ,
code =
client :
loop ()
if not res then
log (
'loop error' ,
res ,
err ,
code )
os.sleep (
1 )
Threads: 48
Wow, brilliant!
Sent one more PM.
Threads: 48
I have tested this and it works just as expected.
Thank you again for your kind help.
Threads: 0
Thanks for the info
Can you give me information about how to load the azure.crt file?
Thank you
Threads: 43
Enable FTP server in System Config, then use ftp account and upload azure.crt to top level directory. Script has correct path set already.
Threads: 0
(04.02.2019, 14:50) admin Wrote: Enable FTP server in System Config, then use ftp account and upload azure.crt to top level directory. Script has correct path set already.regards
Sorry for the inconvenience. I can not load the azure.crt file in the directory
Threads: 43
You can save crt file via a script, run once.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
crt =
[[-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----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MIIEMzCCAxugAwIBAgIDCYPzMA0GCSqGSIb3DQEBCwUAME0xCzAJBgNVBAYTAkRF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-----END CERTIFICATE-----]]
io.writefile (
'/home/ftp/azure.crt' ,
crt )
Threads: 0
05.02.2019, 14:35
(This post was last modified: 05.02.2019, 14:35 by Duvan2127 .)
regards
You can help me with the information required to send data to iot hub de azure. I'm using a logicmachine5 reactor to monitor variables related to electrical energy, I need to send and monitor them in the cloud.
Thank you
(05.02.2019, 07:38) administración Wrote: Puede guardar el archivo crt a través de un script, ejecútelo una vez.
crt =
io.writefile (
crt )
Gracias por la info
Threads: 43
Here'se a scheduled script that forms a JSON-encoded string with object values and then pushes them to Azure, then disconnects:
require (
'json' )
data =
json.encode ({
obj1 =
grp.getvalue (
'32/1/1' ),
obj2 =
grp.getvalue (
'32/1/2' ),
device_id =
'DEV_TEST'
broker =
port =
8883
username =
password =
mqtt =
require (
'mosquitto' )
client =
mqtt.new (
device_id )
running =
true
client.ON_CONNECT =
function (
stat ,
code ,
err )
if stat then
client :
publish (
'devices/' ..
device_id ..
data )
log (
'mqtt connect error' ,
err ,
code )
client :
disconnect ()
running =
false
client :
version_set (
client :
tls_set (
client :
login_set (
username ,
password )
res ,
err =
client :
connect (
broker ,
port )
if not res then
log (
'mqtt initial connect error' ,
err )
running =
false
if res then
while running do
res ,
err ,
code =
client :
loop ()
if not res then
if running then
log (
'mqtt loop error' ,
err ,
code )
break
log (
'mqtt connection failed' ,
err )
Threads: 0
(07.02.2019, 09:04) administración Wrote: Here'se a scheduled script that forms a JSON-encoded string with object values and then pushes them to Azure, then disconnects:
require (
'json' )
data =
json.encode ({
obj1 =
grp.getvalue (
'32/1/1' ),
obj2 =
grp.getvalue (
'32/1/2' ),
device_id =
'DEV_TEST'
broker =
port =
8883
username =
password =
mqtt =
require (
'mosquitto' )
client =
mqtt.new (
device_id )
running =
true
client.ON_CONNECT =
function (
stat ,
code ,
err )
if stat then
client :
publish (
'devices/' ..
device_id ..
data )
log (
err ,
code )
client :
disconnect ()
running =
false
client :
version_set (
client :
tls_set (
client :
login_set (
username ,
password )
res ,
err =
client :
connect (
broker ,
port )
if not res then
log (
err )
running =
false
if res then
while running do
res ,
err ,
code =
client :
loop ()
if not res then
if running then
log (
'mqtt loop error' ,
err ,
code )
break
log (
err )
thanks for the info
With this code I could not connect to azureiotcentral.
apps.azureiotcentral.com
Threads: 43
You need specify correct device_id, broker, username and password parameters. Follow this guide:
Threads: 14
I'm having trouble to connect to IoTCentral too. Is it possible to use this to IoTCentral or just with IoTHub?
Threads: 100
Duvan2127 has contacted Microsoft support in this matter. Here is a reply from MS. Maybe
Duvan2127 can provide further comments or tests done for this?
Step 1 : Get Connection string from the tool. It will give to Hub name
Example
C:\Users\anhashia\AppData\Roaming\npm\node_modules\dps-keygen\bin\windows>dps_cstr 0ne000475B9 mydevice ********************
Registration Information received from service: iotc-3d8d214e-281d-454a-9c7d-259fd8bb49ed.azure-devices.net!
Connection String :
HostName=iotc-3d8d214e-281d-454a-9c7d-259fd8bb49ed.azure-devices.net;DeviceId=mydevice;SharedAccessKey=**************
Once you have connection string, you can put in IoT SDK and you are good to go,
https://docs.microsoft.com/en-us/azure/i...-telemetry
Step 2: Fill below paraments from Step 1 Example.
broker : iotc-3d8d214e-281d-454a-9c7d-259fd8bb49ed.azure-devices.net
port : 8883
device_id : mydevice
username : iotc-3d8d214e-281d-454a-9c7d-259fd8bb49ed.azure-devices.net/mydevice/api-version=2016-11-14
password: This you will need to generate
https://docs.microsoft.com/en-us/azure/i...ity-tokens .
It has code snippet .
Step #5, you need to write code to generate SAS token.
Threads: 48
The certificate we use here. Does it need to renewed at some point, or is it permanent the way it is?
Threads: 43
One of the certificates in the chain is valid until 2025, others even more. You view certificate info here by pasting certificate data:
https://www.sslshopper.com/certificate-decoder.html
Threads: 48
Ok - thank you for the info.
Have you developed any update mechanism on your end that you would like to share, or should we just write one ourselves?
