Smartphone visualization - invert boolean rocket icon
I have a question, and I don't know how to look for it in the forum, so I apologize if it's been answered before.
In a project, I have a boolean object that is ON with a 0 and OFF with a 1. When I use the custom values, I can fix the text names. In the normal visualization also, where I can choose what icon goes with ON and OFF.
But when I use the rocket in the smartphone visualization, I can't change it. Is there any way to do this?
This cannot be configured, but you can use a virtual object as a work-around.
Event script for main object (1/1/1):
if event.sender ~= 'se' then   value = event.getvalue()   grp.write('32/1/1', not value) end
Event script for virtual object (32/1/1):
if event.sender ~= 'se' then   value = event.getvalue()   grp.write('1/1/1', not value) end
(07.02.2019, 08:31)admin Wrote: This cannot be configured, but you can use a virtual object as a work-around.
Thanks admin, I'll try it and feedback you when it's done
