DALI DT-6
I currently have a DALI DT-6 lighting with warm white LED and cold white (2700 to 6500 K) do not have a DT-8 so I have two different ballasts I could create a script that achieves the following command:
- ON / OFF GENERAL
- GENERAL ON / OFF STATUS
- WHITE VARIATION
- STATE VARIATION WHITE
I currently have the following group addresses:
On / off cold dali (0/0/1)
state on / off cold dali (0/1/1)
cold dali value (0/4/1)
state dali value cold (0/3/1)
On / off hot dali (0/0/2)
state on / off hot dali (0/1/2)
hot dali value (0/3/2)
state dali value hot (0/4/2)
I create a script that takes all the following states but I think it can be optimized and I do not recover the white dimming state when I change only cold dali value (0/3/1) ...
Script:
value = grp.getvalue ('32/1/1 ') --white color
if value == 6500 then
  grp.write ('0/3/1', 100)
  grp.write ('0/3/2', 0)
elseif value == 6481 then
  grp.write ('0/3/2', 1)
etc .... Sad  up to 2700 K ... Sad
I put my table excel with the set of values ...
Why not use a formula to calculate warm/cold white values based on color temp instead of copy-pasting hundreds lines of code? Smile
For control you probably need just two objects: dimming and color temperature. If binary control is also needed you just create a script that sets dimming and color temperature to preset values.
(20.02.2019, 07:39)admin Wrote: Why not use a formula to calculate warm/cold white values based on color temp instead of copy-pasting hundreds lines of code? Smile
Yes,
The script with formula :
valtemp = grp.getvalue('34/1/7')
val1= (valtemp - 2700)/19
val2= (6500 - valtemp)/19
if valtemp <=4600 then
  grp.write('34/1/3', 100)
  grp.write('34/1/4', val1)
elseif valtemp >4600 then
  grp.write('34/1/3', val2)
  grp.write('34/1/4', 100)
Just for my table excel if you put values such as 10% cold and 10% hot there will be no match.
B.R.
