04.04.2019, 21:16
		Hello
So the following problem is as follows.
I click on the GA that i want to export to bacnet. And read the via Yabe and other Bacnet browsers like SIEMENS bacnet browser.
So far so good.
Then i import the bacnet point into 3 party software like SIEMENS Xworks CFC.
i copy the bacnet point to an AI BLOCK and paste it in.
Then i get an communication error from the bacnet point. Some of them show the correct temperature, but shortly show communication error.
Corresponding to the bacnet standard.
Then i set the polling time to a minute or something for example. Then the Rlb pin change from Reliability to "Target object unknown".
Also this corresponding to bacnet standard.
I then change the Cov from 1 to 0.1 to see if this triggers more action. But still same error.
Then i change the Group adresss to read value every 60 seconds. And read on startup(guess this dont make any change) This seems to set the block in the third party correct as it shows the correct value and nothing is a problem.
Seems to be working fine, but do people have this big of a deal exporting GA to bacnet. Or is it something that i am doing wrong.?
So far so good.
