23.03.2018, 10:47
is there an app or something to configure and monitoring dali ballasts and devices?
Tnx
Peppe
Tnx
Peppe
					DALI MANAGEMENT
		23.03.2018, 10:47
		Hi,  is there an app or something to configure and monitoring dali ballasts and devices? Tnx Peppe
		23.03.2018, 12:36
		Hi  For configuration the external tools are best like this http://www.tridonic.com/com/en/software-...urator.asp You can monitor by scripts. All the commands are here http://openrb.com/docs/dali.htm There is an app on its way but it is in beta state right now. BR
------------------------------ Ctrl+F5
		26.03.2018, 10:42
	 (23.03.2018, 12:36)Daniel. Wrote: Hi
		29.04.2019, 11:17
(This post was last modified: 29.04.2019, 11:18 by fabiorusco.)
		Hello, I was in a underground tunnel without possibility to connect to internet. I needed install DALI app in a Spacelynk, but browser wrote "DNS error". Can I install from file the dali app? Where i can find it? When i backup a visualisation with app the app are not backupped. What I must do for have the comoplete backup? Best regards.
		29.04.2019, 11:41
		Hi It is SE app and they do not want to share it as a file. You need to ask SE but I heard you already did. BR
		29.04.2019, 11:56
		Hi, If I create visualisation on a homelink connetcted to internet and insert the app fon each dali gateway,the only mode to transfer the full visualizzation on Spacelynk is manipolate the sd card internal of spacelynk/homelynk? Best regards FR
		29.04.2019, 12:53
(This post was last modified: 29.04.2019, 12:54 by fabiorusco.)
		extract it and duplicate? Also if i prepare on homelynk and transfer on spacelink? FR
		29.04.2019, 13:11
		No this will not work. Image from SL will not work on HL and other way around.  Project backup can be transferred.
		29.04.2019, 13:51
		but so I can't transfer the app. FR |
