[?] table name LUA
hi
is there any chance to read JSON names with numbers such as
"102010029"
i want to fetch content from DWD (german weather service)
there is also an isue within openweathermap. Rain forecast "3h" coulndt be used.
i hope aim is clear.
Best
Can you post an example JSON data?
openweathermap
{"cod":"200","message":0.007,"cnt":4,"list":[{"dt":1558386000,"main":{"temp":14.3,"temp_min":14.3,"temp_max":15.5,"pressure":1001.47,"sea_level":1001.47,"grnd_level":996.74,"humidity":92,"temp_kf":-1.2},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":65},"wind":{"speed":3.01,"deg":103.039},"rain":{"3h":0.188},"sys":{"pod":"n"},"dt_txt":"2019-05-20 21:00:00"},{"dt":1558396800,"main":{"temp":12.75,"temp_min":12.75,"temp_max":13.65,"pressure":1001.89,"sea_level":1001.89,"grnd_level":997.71,"humidity":92,"temp_kf":-0.9},"weather":[{"id":803,"main":"Clouds","description":"Überwiegend bewölkt","icon":"04n"}],"clouds":{"all":53},"wind":{"speed":2.77,"deg":108.402},"rain":{},"sys":{"pod":"n"},"dt_txt":"2019-05-21 00:00:00"},{"dt":1558407600,"main":{"temp":11.96,"temp_min":11.96,"temp_max":12.56,"pressure":1002.67,"sea_level":1002.67,"grnd_level":998.5,"humidity":93,"temp_kf":-0.6},"weather":[{"id":801,"main":"Clouds","description":"Ein paar Wolken","icon":"02n"}],"clouds":{"all":21},"wind":{"speed":2.53,"deg":85.688},"sys":{"pod":"n"},"dt_txt":"2019-05-21 03:00:00"},{"dt":1558418400,"main":{"temp":15.45,"temp_min":15.45,"temp_max":15.75,"pressure":1003.2,"sea_level":1003.2,"grnd_level":999.07,"humidity":83,"temp_kf":-0.3},"weather":[{"id":801,"main":"Clouds","description":"Ein paar Wolken","icon":"02d"}],"clouds":{"all":12},"wind":{"speed":3.05,"deg":96.72},"sys":{"pod":"d"},"dt_txt":"2019-05-21 06:00:00"}],....
DWD
"112063000":[{"end":1558379700000,"regionName":"Kreis Havelland","start":1558377900000,"type":0,"state":"Brandenburg","level":2,"headline":"Amtliche WARNUNG vor GEWITTER","description":"Es treten Gewitter auf. Dabei gibt es Windböen mit Geschwindigkeiten bis 60 km/h (17m/s, 33kn, Bft 7).","stateShort":"BB","instruction":"ACHTUNG! Hinweis auf mögliche Gefahren: Örtlich kann es Blitzschlag geben. Bei Blitzschlag besteht Lebensgefahr!","altitudeStart":null,"altitudeEnd":null,"event":"GEWITTER"}],
Example:
require('json') data = '{"112063000":[{"end":1558379700000,"regionName":"Kreis Havelland","start":1558377900000,"type":0,"state":"Brandenburg","level":2,"headline":"Amtliche WARNUNG vor GEWITTER","description":"Es treten Gewitter auf. Dabei gibt es Windböen mit Geschwindigkeiten bis 60 km/h (17m/s, 33kn, Bft 7).","stateShort":"BB","instruction":"ACHTUNG! Hinweis auf mögliche Gefahren: Örtlich kann es Blitzschlag geben. Bei Blitzschlag besteht Lebensgefahr!","altitudeStart":null,"altitudeEnd":null,"event":"GEWITTER"}]}' decoded = json.decode(data) log(decoded['112063000'][1])
(21.05.2019, 06:12)admin Wrote: Example:
thank. sorry I was not precize enought.
here is the JSON
https://www.dwd.de/DWD/warnungen/warnapp...nings.json
I would need to pick "112063000" out of it.
But I guess leading number is the problem as it is for "3h" is...
Best
