30.05.2019, 16:04 (This post was last modified: 30.05.2019, 16:06 by puntukas.)
Hi!
I have Paradox alarm system getaway connected to my KNX bus.
Constantly I get one PGM event (value 0) on specific address several times per day even nothing really happens there (this event is for alarm restore, normally it occurs then systems restores from alarm).
I thought it was Paradox fault, however logs show that LogicMachine (x.x.200) generates this event first and then paradox gateway (x.x.102) comes into the scene (see picture).
Paradox log shows no events from system at all on this time.
Could anybody explain this or point any ideas what's happening?
30.05.2019, 16:13 (This post was last modified: 30.05.2019, 16:13 by puntukas.)
Hi, thanks for such quick replay.
No, no poll interval. There is no noticeable intervals between these false values - there could be three per day with various intervals or just one.
Use ETS monitor to find out what physical device is sending the read request.
Hi, ETS shows the same - LM generates some request - Paradox GW answers. How ever I cant find any peace code that generates requests. As you can see from log - LM generates requests to addresses from 5/0/7 to 5/0/11. What piece of code shall I look for? Or there could be another problem?
Object logs entry should display local instead of physical address as source when LM is sending the telegram internally so it's probably coming from somewhere else. Do you have any other KNX/IP devices on the same network?
changed knx address, changed multicast address, rebooted - two wrong group telegrams generated just after reboot. Can't catch this moment with ETS, because while LM rebooting - there is no interface for KNX/IP. LM log for this object shows the same - "bus". Rebooted 3 times - everytime after reboot - two telegrams for 5/0/10 with "0". Any ideas?
I have had a sort of same situation with a specific Paradox to KNX gateway, can you please provide the manufacturer of the gateway? I might have a suggestion.
