Attempt to index a nil value when sending email with lua
I'm trying to send an email in lua with slightly modified code from documentation:
  -- SMTP settings
  local settings = {
    from = 'mail@example.com',
    user = 'mail@example.com',
    password = 'password',
    server = 'smtp.office365.com',
    port = XYZ,
    secure = 'starttls',
  -- message headers and body
    headers = {
      to = escape(to),
      subject = subject,
      ['Content-type'] = 'text/html; charset=utf-8',
    body = message
  -- fixup from field
  settings.from = escape(settings.from)
  settings.rcpt = { escape(to) }
  return smtp.send(settings)
Even if I use the original documentation code I get an error:
Error in /usr/lib/lua/socket/tp.lua at line 0: attempt to index a nil value
I did not create tp.lua and unfortunately when I try to open it I get this:
Quote:The file is not displayed in the editor because it is either binary or uses an unspupported text encoding.
Does it have Keep source unselected?
Are you asking if I have it in Scripting > User Libraries ? Like those:
[Image: FELDp4R.png]
No, I don't, these are all that are there and all of them have keep source checked.
OK, this is internal library. This is question to admin then.
Can you send access details via PM so I can check locally?
