TCP connection
I must connect with a device which is a gateway for CAN-based system via TCP which sends and receive frames with RAW data.
Do you know how can I create such mechanism?
Frame size is from 29 to 37 bytes and this is start-bit: "0F" and this is stop-bit: "04".
I've tried based on available other integration manuals and all did is that I can send to the bus command and it works:
require('socket')
ip = '192.168.0.15'
port = 10001
cmd = string.char(0x0F, 0x00, 0x10, 0x00, 0x00, 0x80, 0x01, 0x00, 0x01, 0x04, 0x00, 0x01, 0x00, 0x00, 0x5A, 0x04)
sock = socket.tcp()
sock:settimeout(3)
res, err = sock:connect(ip, port)
if res then
 res, err = sock:send(cmd)
 if res then
   print('send OK')
   print('send failed: ' .. tostring(err))
 print('connect failed: ' .. tostring(err))
sock:close()
But this is easier than receiving data and checking from which point the frame startsSad
