Help me! Notification SMS from LM using Twilio service
in the code:
  1. value = event.getvalue()
  2.
  3. from_nr = '+37112345679' -- put sender SIM nr here
  4. to_nr = '+37112345678' -- put recepient SIM nr here
  5. id_nr = 'ACe56f5' -- put your ID here
  6. token_nr = '598c6ff' -- put your token here
  7.
  8. sms(id_nr, token_nr, from_nr, to_nr, 'The value for 1/1/2 has changed to'..tostring(value))
id_nr and token_nr, Where I see my account?
thank everyone. !  Heart Heart Heart
Have a look here:
https://www.twilio.com/help/faq/twilio-b...-change-it
id_nr is your Account SID and token_nr is your Auth Token
(02.03.2016, 12:29)admin Wrote: Have a look here:
thank admin so much!
"from_nr" and "to_nr" , what it?
thank all!  Confused Confused
from_nr is Twilio number that is sending the message, in your Twilio account click "Get your first Twilio Number"
to_nr is the phone number that should receive the message
I try to sent SMS by Twilio in VietNam as link:
https://openrb.com/notification-sms-from...desyntax_2
But, it's not working. I used this code for event:
from_nr = '+19177461563' -- Twilio phone number
to_nr = '+84932414151' -- My phone number
id_nr = '...' -- ACCOUNT SID
token_nr = '...' -- AUTH TOKEN
sms(id_nr, token_nr, to_nr, from_nr, 'Test SMS by SL'..tostring(value))
You have swapped from/to fields. It should be:
sms(id_nr, token_nr, from_nr, to_nr, 'Test SMS by SL'..tostring(value))
(11.10.2019, 06:52)admin Wrote: You have swapped from/to fields. It should be:
Same trouble Sad
My Common Funtions:
--SMS by Twilio
function sms(id, token, from, to, body)
  local escape = require('socket.url').escape
  local request = require('ssl.https').request
  local url = string.format('https://%s:%s@api.twilio.com/2010-04-01/Accounts/%s/Messages.json', id, token, id)
  local body = string.format('From=%s&To=%s&Body=%s', escape(from), escape(to), escape(body))
  return request(url, body)
My Event:
from_nr = '+19177461563' -- put sender SIM nr here
to_nr = '+84938354162' -- put recepient SIM nr here
id_nr = '...' -- put your ID here
token_nr = '...' -- put your token here
Replace sms function with this one:
  local resp = {}
  local stat, code, hdrs = request({
    method = 'POST',
    url = url,
    protocol = 'tlsv12',
    sink = ltn12.sink.table(resp),
    source = ltn12.source.string(body),
    headers = {
      ['content-length'] = #body,
      ['content-type'] = 'application/x-www-form-urlencoded'
  if stat then
    stat = table.concat(resp)
  return stat, code, hdrs
(15.10.2019, 13:53)admin Wrote: Replace sms function with this one:
  local resp = {}
    method = 'POST',
    url = url,
    headers = {
  if stat then
It's working!! Thank you so much Smile
But it takes about 15 min for 1 SMS, too long
You can try contacting Twilio support or ask your local operators if they provide SMS gateway service.
(16.10.2019, 10:38)admin Wrote: You can try contacting Twilio support or ask your local operators if they provide SMS gateway service.
Hi, I tried to send command with https with this code:
local http = require('ssl.https')
mime = require("mime")
res, err = ssl.https.request('https://api.speedsms.vn/index.php/sms/send?access-token=...&to=84938354162&content=hello')
log(res, err)
Log message:
* arg: 1
  * nil
* arg: 2
  * string: Try again
I can send this link from web browser. But, not working with LM5. Please check and tell me how to fix this?
Try updating LuaSocket library (System config > System > Packages > Add (+) green button)
New CPU: https://dl.openrb.com/pkg/luasocket_2.0....9_imx6.ipk
Old CPU: https://dl.openrb.com/pkg/luasocket_2.0....09_mxs.ipk
(18.10.2019, 12:36)admin Wrote: Try updating LuaSocket library (System config > System > Packages > Add (+) green button)
It's work on LM5. How's about the HL&SL? I don't see update packages function in System page
Install latest firmware
(21.10.2019, 09:21)admin Wrote: Install latest firmware
I upgraded to ver 2.4.0. Still same trouble Sad
How can I fix this trouble?? W4K and LM5 can work, SL can not Sad
SL is using all the same libraries as W4K as long you use the same version of FW. If it doesn't work your problem is elsewhere.
Check that your device has correct gateway and DNS set in System config > Network > Interfaces
