21.10.2019, 12:20
Hi:
I'm trying to extract data from Mitsubishi Web Server - SC-SL4
The data to request is:
mensaje = ='<Packet> \r\n' ..
<Command>getRequest</Command> \r\n' ..
<AirConditioner> \r\n' ..
<OpGroup GrNo="1" OnOff="*" Mode="*" ErrorStatus="*"></OpGroup>\r\n' ..
</AirConditioner> \r\n' ..
</Packet>\r\n' ..
The server response 'error 400: syntax error
This is my code:
Content = string.len(mensaje)
soap = '<?xml version="1.0" encoding="UTF-8"?>'
-- http request
reqs = 'POST /servlet/MIMEReceiveServlet.asp HTTP/1.1\r\n'..
'Content-Type: text/xml\r\n'..
'Content-Length: '..Content..'\r\n' ..
'\r\n' ..
soap..'\r\n' ..mensaje
sock = socket.tcp()
sock
ettimeout(70)
res, err = sock:connect(ip, port)
log(res,err)
if res then
res, err = sock
end(reqs)
if res then
log('send OK ')
log('send failed: ' .. tostring(err))
log('connect failed: ' .. tostring(err))
res2, err2 = sock:receive("*a")
sock:close()
log(res2,err2)
The result is nil. We have another installation with another server and LMReactor and it works perfectly.
In this isntallation we have is with LMAmbient
</Packet>\r\n' ..
This is my code:
-- http request
'\r\n' ..
sock = socket.tcp()
sock
ettimeout(70)res, err = sock:connect(ip, port)
log(res,err)
if res then
res, err = sock
end(reqs)if res then
log('send OK ')
sock:close()
log(res2,err2)
