Send an e-mail when the current IP changes
Good morning, I have been searching the Openrb website for a Script through which I get the current IP changes, I am not sure which of the two Script is valid.
I don't know if this script only sends the e-mail if the IP of the LM changes or if the current IP changes:
require('json')
data = io.readproc('if-json')
data = json.decode(data)
ip = data.eth0.inetaddr
ip_old = storage.get('ip_old')
if ip_old == nil then
  storage.set('ip_old', ip)
if ip ~= ip_old then
  subject = 'LM IP changed'
  message = 'The new IP is: ' .. ip
  mail('user@example.com', subject, message)
 - I don't know exactly what we get with this Script
 require('json')
 res = io.readproc('if-json')
 res = json.decode(res)
 ip = res.eth0.inetaddr
 alert('Current LM IP is: %s', ip)
Thank you
 Josema
For external IP use this script: https://forum.logicmachine.net/showthrea...668#pid668
(09.11.2019, 10:19)admin Wrote: For external IP use this script: https://forum.logicmachine.net/showthrea...668#pid668
Thank you very much admin
 Thank you very much admin!
 Josema
 Josema
Hi Josema,
Or maybe this is interesting for you since it gives you a lot more information: https://forum.logicmachine.net/showthrea...8#pid14538
