Tooltip
Hi, is possible to add a tooltip to a link object....???
Please, not only for links but for normal objects too. It would be a great improvement for "user" visualisations.
No solution...???
(13.02.2017, 15:16)cekca Wrote: No solution...???
If this is only for a few points you can prepare widgets and open appropriate by clicking to the value.
What you could do is use the normal text objects and give it a custom class and css to hide it by default. (and optional a background with rounded corners by css)
Then add a custom css class to your object and some custom javascript that detects a hover on the object and toggle the class on the (or group of) text object(s).
This way you can have a tooltip effect.
I don't see any other easier way then this..
Add two classes to the visualization element that you want to have a tooltip: tooltip tooltip-1
Common tooltip class provides the tooltip element itself, while second class (tooltip-1) specifies the tooltip text
Custom CSS, adjust styles and text as needed:
1234567891011121314151617
.usermode .tooltip:before {   display: none;   position: absolute;   top: -30px;   height: 20px;   line-height: 20px;   left: 0;   background-color: #eee;   padding: 2px 6px;   border-radius: 3px; } .usermode .tooltip:hover:before {     display: block; } .usermode .tooltip-1:before {   content: "My custom tooltip"; }
(14.02.2017, 07:45)admin Wrote: Add two classes to the visualization element that you want to have a tooltip: tooltip tooltip-1
Hi Admin, I have tryed this solution, but it doesn't work Sad
Can you explain it better?
It works, only you will see it in the final visu not in editor.
I don't see it even in the final visu..
As the instructions says add the two classes to Additional class of visu element tooltip tooltip-1 and then paste the code to additional css. Have you done all this?
yes I have done it
Send me your backup to PM, use wetransfer.com or similar
ok I found the problem.. if my element is "read-only" the tooltip doesn't work.. I need it to work even if my element is "read-only"
hm. I don't think it will work as when element is read only there is no 'hover' on this element.
As a work around, you can add invisible image and place it under your object. Attach tooltip to the image and it will work.
I have 400 sensors that are read only, it is not a great work around Sad
I have found a solution more elegant and simple for using tooltip with elements that are "read-only".
You have to add only those lines:
.tooltip > div > img {   pointer-events: auto; }
Is there a way to change the text via javascript?
because this code doesn't work
$(".tooltip").mouseover(function(){     $(".usermode .tooltip-1:before").css("content", "test"); });
someone can help me?
Thanks,
Mirco
See this: https://stackoverflow.com/questions/1049...5#42000085
(13.02.2017, 23:34)Erwin van der Zwart Wrote: Hi,
I have try but not found where put the class for object , is possible have one example ?
I have see where set class in the object baut non wher insert the class code for tooltip .
thank's
There is a css section on the graphics tab.
