LM - integration with Mohlenhoff EZR system
This is an example about how LM can integrate in KNX a Mohlenhoff EZR zone heating/cooling system, via XML (parse/change).
Resident script (to regular read the data from EZR controller via XML):
grp.checkupdate = function(alias, newvalue, dpt, mindelta)  local curvalue, valdelta  -- get current object value  curvalue = grp.getvalue(alias)  -- value is numeric and delta is specified  if type(curvalue) == 'number' and type(mindelta) == 'number' then    newvalue = tonumber(newvalue) or 0    valdelta = math.abs(curvalue - newvalue)    -- delta is below minimum, do nothing    if valdelta < mindelta then      return    end  -- do not send same boolean values  elseif type(curvalue) == 'boolean' and curvalue == newvalue then    return  end  grp.update(alias, newvalue, dpt) end http = require('socket.http') url = 'http://192.168.1.111/data/dynamic.xml' function starttag(p, tag, attr)  local nr = tonumber(attr.nr)  table.insert(path, tag)  if nr then    nrtag = tag    table.insert(path, nr)  end end function endtag(p, tag)  table.remove(path)  if tag == nrtag then    nrtag = nil    table.remove(path)  end end function chardata(p, txt)  local ptr, len  txt = txt:trim()  if #txt == 0 then    return  end  ptr = result  len = #path  for i, tag in ipairs(path) do    if i == len then      ptr[ tag ] = txt    elseif not ptr[ tag ] then      ptr[ tag ] = {}    end    ptr = ptr[ tag ]  end end -- current xml tree path path = {} -- resulting table result = {} -- tag name that contains "nr" attribute nrtag = nil lxp = require('lxp') parser = lxp.new({  StartElement = starttag,  EndElement = endtag,  CharacterData = chardata, }) xml = http.request(url) res = parser:parse(xml or '') if res then   log(result.Devices.Device.HEATAREA[ 1 ].HEATAREA_MODE)   log(result.Devices.Device.HEATAREA[ 1 ].T_ACTUAL)   log(result.Devices.Device.HEATAREA[ 1 ].T_TARGET)   log(result.Devices.Device.HEATAREA[ 1 ].PROGRAM_WEEK)   log(result.Devices.Device.HEATAREA[ 1 ].PROGRAM_WEEKEND)   log(result.Devices.Device.HEATAREA[ 1 ].PARTY)   log(result.Devices.Device.HEATAREA[ 1 ].PARTY_REMAININGTIME)   log(result.Devices.Device.HEATAREA[ 1 ].ISLOCKED)   log(result.Devices.Device.IODEVICE[ 1 ].SIGNALSTRENGTH)   log(result.Devices.Device.IODEVICE[ 1 ].BATTERY)     end grp.checkupdate('2/1/1', result.Devices.Device.HEATAREA[ 1 ].HEATAREA_MODE, dt.uint8, 1) grp.checkupdate('2/1/2', result.Devices.Device.HEATAREA[ 1 ].T_ACTUAL, dt.float16, 0.1) grp.checkupdate('2/1/3', result.Devices.Device.HEATAREA[ 1 ].T_TARGET, dt.float16, 0.1) grp.checkupdate('2/1/7', result.Devices.Device.HEATAREA[ 1 ].PROGRAM_WEEK, dt.float16, 1) grp.checkupdate('2/1/8', result.Devices.Device.HEATAREA[ 1 ].PROGRAM_WEEKEND, dt.float16, 1) grp.checkupdate('2/1/9', result.Devices.Device.HEATAREA[ 1 ].PARTY, dt.float16, 1) grp.checkupdate('2/1/10', result.Devices.Device.HEATAREA[ 1 ].PARTY_REMAININGTIME, dt.float16, 1) grp.checkupdate('2/1/12', result.Devices.Device.HEATAREA[ 1 ].ISLOCKED, dt.float16, 1) grp.checkupdate('2/1/13', result.Devices.Device.IODEVICE[ 1 ].SIGNALSTRENGTH, dt.uint8, 1) grp.checkupdate('2/1/14', result.Devices.Device.IODEVICE[ 1 ].BATTERY, dt.uint8, 1)
Event script (writing the data to EZR controller when some data are changed in KNX):
http = require('socket.http') setpoint = event.getvalue() -- format to XY.Z format (1 decimal) setpoint = string.format('%.1f', setpoint) url = 'http://192.168.1.111/data/changes.xml' xml = [[<?xml version="1.0" encoding="UTF-8"?> <Devices>  <Device>    <ID>EZR01233F</ID>    <HEATAREA nr="1">      <T_TARGET>]] .. setpoint .. [[</T_TARGET>    </HEATAREA>  </Device> </Devices>]] socket.http.request(url, xml)
