semaphore unlock after timeout
hi,
is there a way i can i have this to unlock itself after the timeout period executed by the callback?
many thanks,
require('sem')
-- wait for 5 seconds max before executing callback
res1, res2 = sem.runlocked('eventlock', 5, function(lockres)
  -- lock acquired
  if lockres then
    return true, 'lock ok'
  -- failed to acquire lock
    return nil, 'lock failed'
end)
log(res1, res2)
This is not safe because it leads to race conditions which semaphores prevent. Can you explain why do you need this? If your function can fail due to an error you should execute it using pcall().
(06.01.2020, 15:18)admin Wrote: This is not safe because it leads to race conditions which semaphores prevent. Can you explain why do you need this? If your function can fail due to an error you should execute it using pcall().
Ok thanks,
what i am trying to achieve is to have a event script, switch on a group, start a timer then, timeout and switch off a group (also block the resident script from running again while the timer is running )
the event script is triggered by an security alarm message which can happen quite fast (every time the pir is triggered, this is why i want to block the script from running if it has been triggered so i don't have multiple scripts running)
are you able to point me in the right direction.
Many Thanks
Ok thanks,
Many Thanks
Hi!
Perhaps my solution will be useful.
You must create a resident script
local my_tmr_table = storage.get('my_timers')
if my_tmr_table then
    for my_grp,tmr in pairs(my_tmr_table) do
       local my_grp_name = grp.alias(my_grp)
       if my_grp_name then
         if (os.time() - tmr[1]) > tmr[2] then
            grp.write(my_grp,0)
            my_tmr_table [my_grp_name] = nil
         my_grp = nil
storage.set('my_timers', my_tmr_table)
This resident script runs every second and load group objects with UNIX time when timer set (tmr[1]) and for which duration timer set (tmr[2]). If timer for specific group is run out, timer will be destroyed.
Also you need function to set timer
function my_timer (my_grp , on_t , dur)
      my_tmr_table = {}
   k = grp.alias(my_grp)
   my_tmr_table[k] = {on_t,dur}
   storage.set('my_timers',my_tmr_table)
Arguments is:
my_grp - group name
on_t      - UNIX time at timer setup
dur        - duration in seconds
Now you can make script for an group address like this
if event.getvalue()  then
   my_timer (event.dst , os.time() , 300)
In the example above, timer is set to 300 seconds.
Anton
Hi Anton,
Many thanks, this is what i am looking for.
This works well.
