Trend log stopped working
Hi all,
All my trend logs stopped working after a power loss. No errors in the logs and my SD card seems to work properly. Creating a new trend log works, but I would like to revive the old ones to avoid losing all the past data.
Any ideas?
If you reboot do you still have the new trends?
(09.01.2020, 09:08)Daniel. Wrote: If you reboot do you still have the new trends?
Yes, they keep working.
Does anyone know if multiple trend logs impact CPU/IO... I am constantly seing between 0,5 to 0,9 in CPU/IO, and this is a SpaceLYnk for home use, so it is not that many objects that keep writing on the bus at any given time
Mr.D
Trend data is stored once a minute so it can slightly increase the system load but not by a large amount. You can install Processes app to see what is causing the most CPU load on your device.
