Comapration of hours
I am a little novice in this programming through lua.
I need to compare the current time with a specific time to start a device.
How can 3-byte communication objects be compared?
The code used but does not work for me is the following:
1234567891011121314
hora = grp.getvalue('33/0/1')--,dt.time) log (hora) value = grp.getvalue('33/1/21')--,dt.time) log (value) if hora == value then   log ("esto funciona")   total = hora + value   log (total) else   log("ERROR") end
 and I get the following error
123456789101112131415161718192021222324252627282930
Event for Hora Actual (33/0/1) 28.01.2020 16:00:34 * table: [day]   * number: 2 [minute]   * number: 0 [second]   * number: 0 [hour]   * number: 0 [min]   * number: 0 [sec]   * number: 0 Event for Hora Actual (33/0/1) 28.01.2020 16:00:34 * table: [day]   * number: 2 [minute]   * number: 0 [second]   * number: 0 [hour]   * number: 0 [min]   * number: 0 [sec]   * number: 0 Event for Hora Actual (33/0/1) 28.01.2020 16:00:34 * string: ERROR
Can someone please help me?
Thank you
Can you explain what problem are trying to solve? It is easier to compare os.time() You can easily read object update time and compare it with os.time.
Hello Daniel
I am trying to compare the current time with a specific time to be able to perform a series of tasks.
Please, can you help me?
Thank you
Current time with what? There is a lot of different time formats so you need to be more specific.
I want to compare the current time that is type 10. 3 Byte time / day with another time (it would also be type 10. 3 Byte time / day) that the user can put on a page of the visualization to be able to start a pump.
Thank you
OK then you should compare all individual values from the table. hora.day == value.day etc..
Why not use schedulers for this?
I don't use the planner because the time I want to calculate comes from a formula that has a delay or advance of a preset time depending on the pump.
Thanks a lot
You can convert date/time table to minutes and then compare using <, > and ==
minutes = value.hour * 60 + value.min
