Root access.
Does anyone know кщще password? I need to get into the shell, because there are errors on the file system and they need to be fixed.
Feb 5 18:10:16 Podkova-evika kern.info kernel: [ 12.626021] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc Feb 5 18:10:16 Podkova-evika kern.info kernel: [ 12.624906] EXT4-fs (mmcblk0p3): recovery complete Feb 5 18:10:13 Podkova-evika user.info sysinit: /dev/mmcblk0p3: ********** WARNING: Filesystem still has errors ********** Feb 5 18:10:13 Podkova-evika user.info sysinit: e2fsck: unable to set superblock flags on /dev/mmcblk0p3 Feb 5 18:10:12 Podkova-evika user.info sysinit: Run journal anyway? yes Feb 5 18:10:12 Podkova-evika user.info sysinit: Superblock needs_recovery flag is clear, but journal has data. Feb 5 18:10:10 Podkova-evika kern.info kernel: [ 7.034926] fec 800f0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx Feb 5 18:10:09 Podkova-evika user.info sysinit: /dev/mmcblk0p3: recovering journal Feb 5 18:10:08 Podkova-evika user.info sysinit: e2fsck 1.44.1 (24-Mar-2018)
This error leads to the fact that scripts and other settings are not saved :-(
Anton
I strongly suggest replacing SD card
(05.02.2020, 18:42)admin Wrote: I strongly suggest replacing SD card
Hi!
My hardware HW: Reactor v1 (i.MX28). Is the SD card installed inside?
Anton
Yes, you need to open the enclosure to replace it. I recommend using industrial cards.
(07.02.2020, 06:53)admin Wrote: Yes, you need to open the enclosure to replace it. I recommend using industrial cards.
This is new information for me :-)
Thank you!
Best regards,
Anton
