reed and updates on no change
Hi, I am having the issue with a reed connected to the re:actor. It continually sends an update even if nothing has changed. Did I configure something wrong? I only want an action when the value changes.
(15.06.2016, 09:40)managementboy Wrote: Hi, I am having the issue with a reed connected to the re:actor. It continually sends an update even if nothing has changed. Did I configure something wrong? I only want an action when the value changes.
Since I did not get any reply I asume I was not concrete enough. Here a screenshot of the object:
[Image: RTZdN14.png]
And this is the script attached to the object.
if (event.getvalue() > 1) then  -- Door closed  --set status object for door closed  grp.update('4/4/6', true) else  -- Door open  -- set status object for door open  grp.update('4/4/6', false) end
normal is about 1.1V... door open is about 0.6V
What am I doing wrong?
I think you should only send update if previous value was different, like this:
addr = '4/4/6' value = event.getvalue() > 1 if grp.getvalue(addr) ~= value then   grp.update(addr, value) end
(21.06.2016, 13:21)admin Wrote: I think you should only send update if previous value was different, like this:
thank you!! As the Germans say: can't see the forest because of all those trees.
