Logs in visu
Hi all
I'd like to show a user an object log for just one object in my visu. Is it possible?
I know I can show data for trends. But I've not found a way how to do it in case the object has no trend.
When there is no trend attached to the object or the object log is not enabled on this object there is no historical data available for this object anywhere in the system.
You could store historical data to a table in the storage and call it from a .lp file, but i would use a trend as this is the easiest way to do it..
search for eventlog
KNX Advanced Partner + Tutor
.lp file example. Pass object address/name like this: /user/logs.lp?obj=1/1/1
The number of log entries is limited to 100. You can change this value in query if needed.
<? require('apps') alias = getvar('obj') or '' obj = grp.find(alias) if not obj then   print('object not found')   return end ?> <!DOCTYPE html> <html lang="en"> <head>   <meta charset="UTF-8">   <title>Object logs</title>   <link rel="stylesheet" href="/apps/css/bootstrap.css">   <style>     .table { table-layout: fixed; }   </style> </head> <body> <table class="table">   <tr>     <th>Date/time</th>     <th>Source</th>     <th>Event type</th>     <th>Value</th>   </tr> <? query = 'SELECT * FROM objectlog WHERE address=? ORDER BY id DESC LIMIT 100' items = db:getall(query, obj.id) for _, item in ipairs(items) do   datetime = os.date('%c', item.logtime)   if item.src > 0 then     src = buslib.decodeia(item.src)   else     src = 'local'   end   if item.eventtype == 'write' then     value = busdatatype.decode(item.datahex, obj.datatype)   else     value = ''   end ?>   <tr>     <td><?=escape(datetime)?></td>     <td><?=escape(src)?></td>     <td><?=escape(item.eventtype)?></td>     <td><?=escape(value)?></td>   </tr> <? end ?> </table> </body> </html>
(13.02.2020, 08:34)admin Wrote: .lp file example. Pass object address/name like this: /user/logs.lp?obj=1/1/1
Thank you for the file. But there is few issues.
buslib.encodeia(item.src) doesn't work at all. My KNX object which is source of the log record has address 1.3.63.
item.src = 46081
Result of buslib.encodeia(46081) is nil.
I thought there should be buslib.decodeia(item.src) instead of encode. But it doesn't work either. buslib.decodeia(46081) returns 11.4.1 so it looks like there's a bit ordering mismatch etc.
The second problem is:
busdatatype.decode(item.datahex, obj.datatype) returns only basic datatypes. But I'd like to see fully decoded values. Like switch on/off, open/close etc. Is it possible?
In attachments below I'm sending you what I see in log and what's on this newly created page.
Right, it should be buslib.decodeia() instead of buslib.encodeia(). As for wrong address 1.3.63 is 4927 in integer form. You've probably mistaken it with 22/4/1 which is 46081 in integer form.
There are no server-side function for decoding sub-datatypes apart from scaling and angle. You can write your own conversion function if needed.
Try this:
1) Run code below once to create the logs.lp
2) To have normal decoding use http://<ip>/user/logs.lp?obj=1/1/1
3) To use the custom values during decoding http://<ip>/user/logs.ip?obj=1/1/1&custom=true
4) To reduce or increase the number of lines (default 100) use http://<ip>/user/logs.ip?obj=1/1/1&lines=20 or  http://<ip>/user/logs.ip?obj=1/1/1&custom=true&lines=20
dst = '/www/user/logs.lp' io.writefile(dst, [[ <? require('apps') alias = getvar('obj') or '' custom = getvar('custom') or 'false' lines = tonumber(getvar('lines')) or 100 obj = grp.find(alias) if not obj then   print('object not found')   return end function decodevalue(obj, value)   if obj.enums and custom == 'true' then     require('json')     enums = json.pdecode(obj.enums)     if type(value) == 'boolean' then       if value == true then           value = enums['1']       else         value = enums['0']       end     else        value = enums[tostring(value)]     end     if value == nil or value == '' then       value = enums['default']     end   else     dt = {       [1] = {         dttype = 'boolean',         enums = {           [true] = 'true',           [false] = 'false'         }       },       [1001] = {         dttype = 'switch',         enums = {           [true] = 'on',           [false] = 'off'         }       },       [1002] = {         dttype = 'boolean',         enums = {           [true] = 'true',           [false] = 'false'         }       },       [1003] = {         dttype = 'enable',         enums = {           [true] = 'enable',           [false] = 'disable'         }       },       [1004] = {         dttype = 'transition',         enums = {           [true] = 'ramp',           [false] = 'no ramp'         }       },       [1005] = {         dttype = 'alarm',         enums = {           [true] = 'alarm',           [false] = 'no alarm'         }       },       [1006] = {         dttype = 'low/high',         enums = {           [true] = 'high',           [false] = 'low'         }       },       [1007] = {         dttype = 'step',         enums = {           [true] = 'increase',           [false] = 'decrease'         }       },       [1008] = {         dttype = 'up/down',         enums = {           [true] = 'up',           [false] = 'down'         }       },       [1009] = {         dttype = 'open/close',         enums = {           [true] = 'close',           [false] = 'open'         }       },       [1010] = {         dttype = 'start/stop',         enums = {           [true] = 'start',           [false] = 'stop'         }       },       [1011] = {         dttype = 'activity',         enums = {           [true] = 'active',           [false] = 'inactive'         }       },       [1012] = {         dttype = 'inversion',         enums = {           [true] = 'inverted',           [false] = 'not inverted'         }       },       [1013] = {         dttype = 'dim style',         enums = {           [true] = 'cyclically',           [false] = 'start/stop'         }       },       [1014] = {         dttype = 'data source',         enums = {           [true] = 'calculated',           [false] = 'fixed'         }       },       [2] = {         dttype = '2 bit (1 bit controlled)',         enums = {           [0] = 'No control, 0',           [1] = 'No control, 1',           [2] = 'Control, 0',           [3] = 'Control, 1'         }       },       [3] = {         dttype = '4 bit (3 bit controlled)',         enums = {           [0] = 'No control, Break',           [1] = 'No control, Step 1',           [2] = 'No control, Step 2',           [3] = 'No control, Step 3',           [4] = 'No control, Step 4',           [5] = 'No control, Step 5',           [6] = 'No control, Step 6',           [7] = 'No control, Step 7',           [8] = 'Control, Break',           [9] = 'Control, Step 1',           [10] = 'Control, Step 2',           [11] = 'Control, Step 3',           [12] = 'Control, Step 4',           [13] = 'Control, Step 5',           [14] = 'Control, Step 6',           [15] = 'Control, Step 7',         }       },       [3007] = {         dttype = '4 bit dim/blinds step',         enums = {           [0] = 'Stop',           [1] = 'Down 100%',           [2] = 'Down 50%',           [3] = 'Down 25%',           [4] = 'Down 12%',           [5] = 'Down 6%',           [6] = 'Down 3%',           [7] = 'Down 1%',           [8] = 'Stop',           [9] = 'Up 100%',           [10] = 'Up 50%',           [11] = 'Up 25%',           [12] = 'Up 12%',           [13] = 'Up 6%',           [14] = 'Up 3%',           [15] = 'Up 1%',         }       }     }       if dt[obj.datatype] then            value = dt[obj.datatype]['enums'][value]     end     end   return value end ?> <!DOCTYPE html> <html lang="en"> <head>   <meta charset="UTF-8">   <title>Object logs</title>   <link rel="stylesheet" href="/apps/css/bootstrap.css">   <style>     .table { table-layout: fixed; }   </style> </head> <body> <table class="table">   <tr>     <th>Date/time</th>     <th>Source</th>     <th>Event type</th>     <th>Value</th>   </tr> <? query = 'SELECT * FROM objectlog WHERE address=? ORDER BY id DESC LIMIT ?' items = db:getall(query, obj.id, lines) for _, item in ipairs(items) do   datetime = os.date('%c', item.logtime)   if item.src > 0 then     src = buslib.decodeia(item.src)   else     src = 'local'   end   if item.eventtype == 'write' then     value = busdatatype.decode(item.datahex, obj.datatype)     value = decodevalue(obj, value)   else     value = ''   end ?>   <tr>     <td><?=escape(datetime)?></td>     <td><?=escape(src)?></td>     <td><?=escape(item.eventtype)?></td>     <td><?=escape(value)?></td>   </tr> <? end ?> </table> <script type="text/javascript">   var itemsdata = <? json.write(items) ?>;   //console.log(itemsdata); </script> </body> </html> ]]) script.disable(_SCRIPTNAME)
Thank you, works well.
FYI 1009 is wrong. I think it's for Nobel price for someone who invented it but according to KNX specs the correct setting is:
[1009] = {
        enums = {
    [false] = 'open',
    [true] = 'close'
I have the code working fine although been trying to mod (unsuccessfully) I would like to know how I can adjust the coding to give me.
1. Be able display all logged events
2. Be able to provide the user the ability to filter logs. Like using a custom value set against an 2 byte integer (where 0= 1/1/1, 1=1/1/3, 2=32/1/5) where they can choose which group to list, would be nice if the custom value list could automatically be generated / updated with group addresses that have been selected to be logged.
3. To show in the list the actual group address against each event.
Thanks for any suggestions.
