Searching for User Parameters
Hi All,
I'm trying to find a user parameter via a keywork (tag) search rather than the parameter name much like I can do it with other types.  I've looked at running a sql query in a function to do it however I can't seem to associate a keyword with the parameter name.
I can use:
SetUserParam('Local Network', 'w_obs_wind_dirtext', value)
however I want to set the value based on the keywork like
SetCBusByKW({'irrigation_current_runtype'}, 'or', {target = 1, ramprate = 0})
I have some db helper functions like the below, so not opposed to doing something in a query.
function db_GetObjectByTag(tag)
    -- Return a table of object parameters based on the id
    local query = string.format('SELECT * FROM objecttags WHERE tag = "%s"', tag)
    liste = db:getall(query)
    if (table.maxn(liste) ~= 0) then
        return liste
        return false
Cheers,
Paul
Why don't you use build in function?
myobjects = grp.tag('tag')
(12.02.2020, 13:20)Daniel. Wrote: Why don't you use build in function?
I don't have that function on the SCAC available for user parameters. The logic machine is very similar, but with some mods. A lot of the info on this forum is applicable, particularly around the lua scripting options.
User parameter is standard LM object so grp.tag should work. Have you actually tried it?
I tried it on NAC and it works
Yep. tried it and it works for a read, is it possible to write using a similar methos via tag?
Paul
It depend what you want to write.
Pretty much anything that can be written to a user param, string, integer, float.
Writing is done like this:
value = 123 objects = grp.tag('tag') objects:write(value)
Awesome, thats what I need, thanks. Is there documentation available on this type of thing, the CBus documentation is pretty basic.
Cheers,
Paul
See: https://openrb.com/docs/lua.htm
