28.02.2020, 21:00
Hi all,
With every script that runs, I see the following message in the log files:
The following messages appear in the system log:
Any idea how I can check and repair the filesystem? Or how I can figure out which file is causing the issue? Should I replace the SD card?
Quote:* string: [01][03][00][C8][00][01][05][F4]
ERROR Bad file descriptor
Quote:Jan 1 00:00:02 LogicMachine kern.info kernel: [ 0.797559] Waiting for root device /dev/mmcblk0p2...
Jan 1 00:00:02 LogicMachine kern.info kernel: [ 0.808955] mmcblk0: mmc0:59b4 00000 3.67 GiB
Jan 1 00:00:02 LogicMachine kern.info kernel: [ 0.811916] mmcblk0: p1 p2 p3
Jan 1 00:00:02 LogicMachine kern.info kernel: [ 0.905507] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Jan 1 00:00:02 LogicMachine kern.info kernel: [ 0.905568] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Jan 1 00:00:02 LogicMachine kern.info kernel: [ 1.025102] EXT4-fs (mmcblk0p2): recovery complete
Jan 1 00:00:02 LogicMachine kern.info kernel: [ 1.045362] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 1 00:00:02 LogicMachine kern.info kernel: [ 1.045540] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
Jan 1 00:00:02 LogicMachine kern.info kernel: [ 1.905694] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc
Feb 16 04:00:04 LogicMachine user.info sysinit: /dev/mmcblk0p3: recovering journal
Feb 16 04:00:05 LogicMachine user.info sysinit: Setting free inodes count to 126732 (was 0)
Feb 16 04:00:05 LogicMachine user.info sysinit: Setting free blocks count to 482477 (was 0)
Feb 16 04:00:05 LogicMachine user.info sysinit: /dev/mmcblk0p3: clean, 4340/131072 files, 41811/524288 blocks
Feb 16 04:00:05 LogicMachine kern.info kernel: [ 5.865568] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc
Feb 16 04:00:04 LogicMachine user.info sysinit: e2fsck 1.44.5 (15-Dec-2018)
Quote:File system, Total size, Used, Free, Mounted on
/dev/root, 108.0M, 23.3M (22%), 84.6M, /
tmpfs, 61.3M, 24.7M (40%), 36.6M, /tmp
tmpfs, 4.0M, 12.0K (0%), 4.0M, /dev
/dev/mmcblk0p3, 1.9G, 74.8M (4%), 1.8G, /data
