“staircase function”
As a "newcomer" to LM5 as well as Lua scripting, I am struggling with a script, that features kind of a staircase function and that could be parametrised separately to implement a time-controlled lighting of a staircase or similar applications.
- The script would be triggered by a “1 bit object” originating from a motion-sensor
- The script would then dim-on the corresponding lights by sending a “1 byte object” to the dimmer
- Then the script would wait a delay time, after that it would dim down the lights by sending several decreasing values, also with some short delay in between
Well, so far, this was straight forward to implement.
value = event.getvalue()
if value==true then
  grp.write('9/1/3',100)
  sleep(90)
  grp.write('9/1/3',50)
  sleep(15)
  grp.write('9/1/3',30)
  sleep(3)
  grp.write('9/1/3',15)
  sleep(3)
  grp.write('9/1/1',false)
Only, there would be some “extra features” needed:
a) When an another 1 bit object = 1, originating from a motion-sensor would be received during the script-execution, it should reset the initial delay time —> “staircase function” (means, restarting the script immediately)
b) When an object = 1 originating from a wall-switch would be received during the script-execution, it should stop the script, dim up the lights and disable the motion-sensor
c) When an object = 0 originating from a wall-switch would be received during the script-execution, it should stop the script, dim down the lights and disable the motion-sensor
Thank you very much.
Well there are quite some improvements to make as you can’t use event based scripts like this as they will run in parallel if you don’t take care of it.
Here is a sample to start with that already does a lot you need only needs to be modified for your dimming steps, restart and blocking is already implemented.
See: https://forum.logicmachine.net/showthrea...2#pid15442
(11.02.2020, 20:23)Erwin van der Zwart Wrote: Hi,
Hello Erwin
Thank you very much for your quick and helpful reply, critic and valuable suggestion, which I will be happy to try out this Friday. Am I right, by assuming, that your suggested script shall run as a "Resident Script"?
KR, Boris
No you need to run it as event based attached to the input object.
Works great. Thank you, Erwin
