XML data
Hello, I`m looking to import weaterdata from a website.
The site exports data as xml.
Is there a guide to doing so in LM?
Example xml:
https://www.yr.no/sted/Norge/Vestfold_og...varsel.xml
Sent fra min SM-G950F via Tapatalk
require('socket.http') forecast = {} function parsetag(parser, tag, attributes)   if tag == 'time' then     table.insert(forecast, {})   elseif tag == 'symbol' then     forecast[ #forecast ].symbol = attributes.name   elseif tag == 'precipitation' then     forecast[ #forecast ].precipitation = attributes.value   elseif tag == 'windDirection' then     forecast[ #forecast ].wind_direction = attributes.code   elseif tag == 'windSpeed' then     forecast[ #forecast ].wind_speed = attributes.mps   elseif tag == 'temperature' then     forecast[ #forecast ].temperature = attributes.value   elseif tag == 'pressure' then     forecast[ #forecast ].pressure = attributes.value   end end url = 'http://www.yr.no/place/United_Kingdom/England/Farnborough/varsel.xml' data, err = socket.http.request(url) if data then   require('lxp').new({     StartElement = parsetag   }):parse(data)   grp.update('Weather precipitation', tonumber(forecast[1].precipitation))   grp.update('Weather symbol', forecast[1].symbol)   grp.update('Weather windDirection', forecast[1].wind_direction)   grp.update('Weather windSpeed', tonumber(forecast[1].wind_speed))   grp.update('Weather temperature', tonumber(forecast[1].temperature))   grp.update('Weather pressure', tonumber(forecast[1].pressure))   --log(forecast)   else   alert('Fetch failed: ' .. tostring(err)) end
Daniel, is this still working. ?
I think yr.no changed to another api.
https://api.met.no/
Their new beta API provides JSON which is much easier to parse:
https://api.met.no/weatherapi/locationfo...0&lon=9.58
My script still works.
require('ssl.https')
require('json')
data = ssl.https.request('http://weerlive.nl/api/json-10min.php?locatie=' ..plaatsnaam)
datatable = json.pdecode(data)
datatable = datatable['liveweer'][1]
log(datatable)
If you use something like this, how do you deploy it and how do you extract this to groupo adresses?
(18.03.2020, 09:29)admin Wrote: Their new beta API provides JSON which is much easier to parse:
Where do we privide location on this one?
never mind, I see the long lat now Smile
decoding json gives me "nesting to deep" in most of the tables..
What could be the reason for this?
I tried like that you have to put coordinate of location as longitude and latitude.
require('ssl.https') require('json') data = ssl.https.request('https://api.met.no/weatherapi/locationforecast/2.0/.json?lat=51.28&lon=-0.75') datatable = json.pdecode(data) log(datatable.properties.timeseries[1].data.instant.details.air_temperature)
(18.03.2020, 10:22)Daniel. Wrote: I tried like that you have to put coordinate of location as longitude and latitude.
yeah, I got some data, but I also got "nesting to deep" in the log. could try to extract spesiffic data, maybe that would do the trick.
seems to work, but the amount of data in the table is quite big, and difficult to navigate.
Any good tips to view the table in a structured way?
Firefox can display JSON data in a structured way. Or just copy JSON from the URL and use any online JSON viewer.
