Compare times
Hi!
I want to check if the local time is "greater" than a specific time, regardless of date.
As an example I want to check if the clock is more than 19 o'clock.
Is there a simple way to do this? Maybe with just two lines of scripting?
I understand that os.time(os.date('*t')) returns local time as the number of seconds from Thursday, 1 January 1970.
And os.time({year=2001, month=9, day=11, hour=13, minute=46}) returns also the number of seconds from Thursday, 1 January 1970.
But what I really want is os.time({hour=13, minute=46}), which I do not think is possible to write.
And I want to see if this time is before or later the local time os.date('*t'), but just hour and minutes.
Thanks for all your help!!
Kind regards,
Camilla
(22.04.2020, 10:19)camillsg Wrote: Hi!
Kind regards,
Camilla
you can do it like this
local t = os.date("*t") if t.hour == 13 and t.min == 46 then  --do something end -- if hour is greater than or equal to 13.00 if t.hour >=13 then --do something else end
See this: https://forum.logicmachine.net/showthrea...4#pid15434
Kind regards,
Camilla
Thank you so much!!
