How can I create custom package for LM?
I need custom websocket connections with TV and other stuff and I want to use this connection inside LUA resident or event scripts.
The main idea is I create a package which works as HTTP server on some local port and it has and ability to create websocket clients inside.
e.g.
event script
ws = require('lua.websocket')
tvConnection, err = ws.connect('ws://my.tv.ip:3000') -- (blocking with t/o) send to local HTTP server
-- a command to connect if no connection
tvConnection.send('raw data') -- send text or array of bytes to 'ws://my.tv.ip:3000'
resident script 0 sec
data = tvConnection.receive() -- receive array of data came from 'ws://my.tv.ip:3000'
Could you please create kind of this stuff? Or give me instruction how to build own package, I know C/C++, Golang, JS, Lua
Main changes:
1. Support for basic auth in URL
2. Receive timeout does not close the websocket connection
3. Server support is removed
Add it as a user library named websocket
Minimal example (resident script):
if not ws then
ws = require('user.websocket')
url = 'ws://admin:admin@192.168.1.12/apps/localbus.lp'
-- mode is either sync or copas, second parameter sets timeout in seconds
client = ws.client('sync', 10)
client:connect(url)
log(client:receive())
I am trying to use the copas part because being a resident script i need to run a udp server to accept an event script client.
On connecting with the copas parameter I get the following in the error log.
Library copas:0: attempt to yield across C-call boundary
stack traceback:
[C]: in function 'yield'
Library copas: in function 'connect'
User library websocket:500: in function 'sock_connect'
User library websocket:438: in function 'connect'
ws = require("user.websocket")
url = 'ws://demos.kaazing.com/echo'
client = ws.client('copas', 10)
client:connect(url)
I am using the following UDP server code for taking requests from the LM objects. effectively the websockets client needs to running asynchronously so it doesn't block the udp server running. In the past I have used copas to do this.
local server = usocket.udp()
server:setsockname("127.0.0.1",53450)
function handler(skts)
skts = copas.wrap(skts)
alert("UDP connection handler")
while true do
local s, err
alert("UDP receiving..")
s, erro = skts:receive(2048)
if not s then
alert("Receive error: %s", erro)
break
alert("Received data, bytes: %s",s)
-- send to the websocket
client:send(s)
copas.addserver(server, handler, 1)
Is there an example from this? Because that's what I am trying. thx Roger
if not ready then
socket = require("user.websocket")
usocket = require("socket")
copas = require("copas")
ready=true
apps = {}
--helper functions to round and increment values
function increment(n)
n = n + 1
return n
function parse(data)
alert('parsing: %s', data)
local response = string.split(data,' = ')
function sendCommand(command)
skt:send(command)
sleep(1)
function init()
function fromKNX(command)
local telegram = string.split(command,',')
log(command)
while true do
local s, err
if not s then
break
fromKNX(s)
if not skt then
url= 'ws://demos.kaazing.com/echo'
skt,err = socket.client('copas',5)
skt:connect(url,80)
skt:send('hello')
-- when theres no error connect ok, initialize
if(not err) then
-- add receive thread
copas.addthread(function()
while true do
local resp,err = copas.receive(skt)
-- if theres no connection start a new connection
if not resp then
alert("[tcp-client] Receive error: %s", err)
copas.removeserver(skt)
skt = nil
break
local fd,prtd = pcall(parse,resp)
if(fd==false)then
alert("Error with parsemsg %s ",prtd)
end)
if skt then
alert('[tcp-client] connection ok')
init()
-- error while connecting,
if warningfailed then alert('[tcp-client] connection failed (conn): %s', err) end
return
alert('[tcp-client] error connecting %s',err)
return
copas.loop()
Ok adding the connect in the thread works. Thank you. The timeout parameter doesn't seem to have any effect. The connection always lasts about 10 seconds disconnects and reconnects. Is there no way to keep it permanently connected?
Another thing I need to account for is that the webservice is not always running. It's live when the device is powered on. So what I see is that the script would be constantly trying to reconnect. I guess the only way to handle this is by disabling the resident script when the device is powered off. Unless you have any other idea?
Disconnect might happen from the server side. To keep connection alive you probably need to request data periodically or send ping frames.
As for reconnect, enable/disable is one approach, another one is just to keep script running and check if connect is ok or not. When device is offline then connect function will return once timeout is reached.
thanks
Roger
Hi Roger,
Did you have any success getting your LG TV to work with this? Also did you manage to support connecting to multiple clients?
I'm trying to do the same (I have 2 LG WebOS TVs I'd like to control).. but I'm a complete newbie to Lua.
Referring to the WebSocket post, we are able to connect to the web-socket server, but in the CASAMBI API documentation, they have asked to pass the "API-Key" (a string) as "protocol" (under "Create WebSocket Connection" section of documentation). They have also given an example in JavaScript which is shown below. How shall this be implemented using LM WebSocket Library. ? we tried but it is not working (in LM Ambient)
You need to modify the upgrade_request function in websocket library:
local upgrade_request = function(req, key)
local format = string.format
local lines = {
format('GET %s HTTP/1.1',req.path or ''),
format('Host: %s',req.host),
'Upgrade: websocket',
'Connection: Upgrade',
format('Sec-WebSocket-Key: %s',key),
'Sec-WebSocket-Version: 13',
if self.protocol then
tinsert(lines, format('Sec-WebSocket-Protocol: %s', self.protocol))
if req.port and req.port ~= 80 then
lines[2] = format('Host: %s:%d',req.host,req.port)
if req.userinfo then
local auth = format('Authorization: Basic %s', base64enc(req.userinfo))
tinsert(lines, auth)
tinsert(lines,'\r\n')
return tconcat(lines,'\r\n')
Then create connection like this (change API key):
(11.05.2020, 06:52)admin Wrote: You need to modify the upgrade_request function in websocket library:
local lines = {
After making the changes in library, it throws the following error:-
User library websocket:292: attempt to index global 'self' (a nil value)
stack traceback:
User library websocket:292: in function 'upgrade_request'
User library websocket:462: in function 'connect'
User script:8: in main chunk
local bit = require('bit')
local ssl = require('ssl')
local encdec = require('encdec')
local parse_url = require('socket.url').parse
local bxor = bit.bxor
local bor = bit.bor
local band = bit.band
local lshift = bit.lshift
local rshift = bit.rshift
local ssub = string.sub
local sbyte = string.byte
local schar = string.char
local tinsert = table.insert
local tconcat = table.concat
local mmin = math.min
local mfloor = math.floor
local mrandom = math.random
local base64enc = encdec.base64enc
local sha1 = encdec.sha1
local unpack = unpack
local CONTINUATION = 0
local TEXT = 1
local BINARY = 2
local CLOSE = 8
local PING = 9
local PONG = 10
local guid = '258EAFA5-E914-47DA-95CA-C5AB0DC85B11'
local read_n_bytes = function(str, pos, n)
pos = pos or 1
return pos+n, string.byte(str, pos, pos + n - 1)
local read_int8 = function(str, pos)
return read_n_bytes(str, pos, 1)
local read_int16 = function(str, pos)
local new_pos,a,b = read_n_bytes(str, pos, 2)
return new_pos, lshift(a, 8) + b
local read_int32 = function(str, pos)
local new_pos,a,b,c,d = read_n_bytes(str, pos, 4)
return new_pos,
lshift(a, 24) +
lshift(b, 16) +
lshift(c, 8 ) +
d
local write_int8 = schar
local write_int16 = function(v)
return schar(rshift(v, 8), band(v, 0xFF))
local write_int32 = function(v)
return schar(
band(rshift(v, 24), 0xFF),
band(rshift(v, 16), 0xFF),
band(rshift(v, 8), 0xFF),
band(v, 0xFF)
local generate_key = function()
math.randomseed(os.time())
local r1 = mrandom(0,0xfffffff)
local r2 = mrandom(0,0xfffffff)
local r3 = mrandom(0,0xfffffff)
local r4 = mrandom(0,0xfffffff)
local key = write_int32(r1)..write_int32(r2)..write_int32(r3)..write_int32(r4)
return base64enc(key)
local bits = function(...)
local n = 0
for _,bitn in pairs{...} do
n = n + 2^bitn
return n
local bit_7 = bits(7)
local bit_0_3 = bits(0,1,2,3)
local bit_0_6 = bits(0,1,2,3,4,5,6)
-- TODO: improve performance
local xor_mask = function(encoded,mask,payload)
local transformed,transformed_arr = {},{}
-- xor chunk-wise to prevent stack overflow.
-- sbyte and schar multiple in/out values
-- which require stack
for p=1,payload,2000 do
local last = mmin(p+1999,payload)
local original = {sbyte(encoded,p,last)}
for i=1,#original do
local j = (i-1) % 4 + 1
transformed[i] = bxor(original[i],mask[j])
local xored = schar(unpack(transformed,1,#original))
tinsert(transformed_arr,xored)
return tconcat(transformed_arr)
local encode_header_small = function(header, payload)
return schar(header, payload)
local encode_header_medium = function(header, payload, len)
return schar(header, payload, band(rshift(len, 8), 0xFF), band(len, 0xFF))
local encode_header_big = function(header, payload, high, low)
return schar(header, payload)..write_int32(high)..write_int32(low)
local encode = function(data,opcode,masked,fin)
local header = opcode or 1-- TEXT is default opcode
if fin == nil or fin == true then
header = bor(header,bit_7)
local payload = 0
if masked then
payload = bor(payload,bit_7)
local len = #data
local chunks = {}
if len < 126 then
payload = bor(payload,len)
tinsert(chunks,encode_header_small(header,payload))
elseif len <= 0xffff then
payload = bor(payload,126)
tinsert(chunks,encode_header_medium(header,payload,len))
elseif len < 2^53 then
local high = mfloor(len/2^32)
local low = len - high*2^32
payload = bor(payload,127)
tinsert(chunks,encode_header_big(header,payload,high,low))
if not masked then
tinsert(chunks,data)
local m1 = mrandom(0,0xff)
local m2 = mrandom(0,0xff)
local m3 = mrandom(0,0xff)
local m4 = mrandom(0,0xff)
local mask = {m1,m2,m3,m4}
tinsert(chunks,write_int8(m1,m2,m3,m4))
tinsert(chunks,xor_mask(data,mask,#data))
return tconcat(chunks)
local decode = function(encoded)
local encoded_bak = encoded
if #encoded < 2 then
return nil,2-#encoded
local pos,header,payload
pos,header = read_int8(encoded,1)
pos,payload = read_int8(encoded,pos)
local high,low
encoded = ssub(encoded,pos)
local bytes = 2
local fin = band(header,bit_7) > 0
local opcode = band(header,bit_0_3)
local mask = band(payload,bit_7) > 0
payload = band(payload,bit_0_6)
if payload > 125 then
if payload == 126 then
pos,payload = read_int16(encoded,1)
elseif payload == 127 then
if #encoded < 8 then
return nil,8-#encoded
pos,high = read_int32(encoded,1)
pos,low = read_int32(encoded,pos)
payload = high*2^32 + low
if payload < 0xffff or payload > 2^53 then
assert(false,'INVALID PAYLOAD '..payload)
bytes = bytes + pos - 1
local decoded
if mask then
local bytes_short = payload + 4 - #encoded
if bytes_short > 0 then
return nil,bytes_short
local m1,m2,m3,m4
pos,m1 = read_int8(encoded,1)
pos,m2 = read_int8(encoded,pos)
pos,m3 = read_int8(encoded,pos)
pos,m4 = read_int8(encoded,pos)
local mask = {
m1,m2,m3,m4
decoded = xor_mask(encoded,mask,payload)
bytes = bytes + 4 + payload
local bytes_short = payload - #encoded
if #encoded > payload then
decoded = ssub(encoded,1,payload)
decoded = encoded
bytes = bytes + payload
return decoded,fin,opcode,encoded_bak:sub(bytes+1),mask
local encode_close = function(code,reason)
if code then
local data = write_int16(code)
if reason then
data = data..tostring(reason)
return data
return ''
local decode_close = function(data)
local _,code,reason
if data then
if #data > 1 then
_,code = read_int16(data,1)
if #data > 2 then
reason = data:sub(3)
return code,reason
local sec_websocket_accept = function(sec_websocket_key)
local enc = sha1(sec_websocket_key..guid, true)
return base64enc(enc)
local http_headers = function(request)
local headers = {}
if not request:match('.*HTTP/1%.1') then
return headers
request = request:match('[^\r\n]+\r\n(.*)')
for line in request:gmatch('[^\r\n]*\r\n') do
local name,val = line:match('([^%s]+)%s*:%s*([^\r\n]+)')
if name and val then
name = name:lower()
if not name:match('sec%-websocket') then
val = val:lower()
if not headers[name] then
headers[name] = val
headers[name] = headers[name]..','..val
elseif line ~= '\r\n' then
assert(false,line..'('..#line..')')
return headers,request:match('\r\n\r\n(.*)')
local upgrade_request = function(req, key, protocol)
local lines = {
if protocol then
tinsert(lines, format('Sec-WebSocket-Protocol: %s', protocol))
local receive = function(self)
if self.state ~= 'OPEN' and not self.is_closing then
return nil,nil,false,1006,'wrong state'
local first_opcode
local frames
local bytes = 3
local encoded = ''
local clean = function(was_clean,code,reason)
self.state = 'CLOSED'
self:sock_close()
if self.on_close then
self:on_close()
return nil,nil,was_clean,code,reason or 'closed'
while true do
local chunk,err = self:sock_receive(bytes)
if err then
if err == 'timeout' then
return nil,nil,false,1006,err
return clean(false,1006,err)
encoded = encoded..chunk
local decoded,fin,opcode,_,masked = decode(encoded)
if masked then
return clean(false,1006,'Websocket receive failed: frame was not masked')
if decoded then
if opcode == CLOSE then
if not self.is_closing then
local code,reason = decode_close(decoded)
-- echo code
local msg = encode_close(code)
local encoded = encode(msg,CLOSE,true)
local n,err = self:sock_send(encoded)
if n == #encoded then
return clean(true,code,reason)
return clean(false,code,err)
return decoded,opcode
if not first_opcode then
first_opcode = opcode
if not fin then
if not frames then
frames = {}
elseif opcode ~= CONTINUATION then
return clean(false,1002,'protocol error')
bytes = 3
encoded = ''
tinsert(frames,decoded)
elseif not frames then
return decoded,first_opcode
return tconcat(frames),first_opcode
assert(type(fin) == 'number' and fin > 0)
bytes = fin
local send = function(self,data,opcode)
if self.state ~= 'OPEN' then
return nil,false,1006,'wrong state'
local encoded = encode(data,opcode or TEXT,true)
if n ~= #encoded then
return nil,self:close(1006,err)
return true
local close = function(self,code,reason)
return false,1006,'wrong state'
if self.state == 'CLOSED' then
local msg = encode_close(code or 1000,reason)
local was_clean = false
code = 1005
reason = ''
self.is_closing = true
local rmsg,opcode = self:receive()
if rmsg and opcode == CLOSE then
code,reason = decode_close(rmsg)
was_clean = true
reason = err
self:sock_close()
self:on_close()
return was_clean,code,reason or ''
local DEFAULT_PORTS = {ws = 80, wss = 443}
local connect = function(self,ws_url,ssl_params)
if self.state ~= 'CLOSED' then
return nil,'wrong state',nil
local parsed = parse_url(ws_url)
if parsed.scheme ~= 'wss' and parsed.scheme ~= 'ws' then
return nil, 'bad protocol'
if not parsed.port then
parsed.port = DEFAULT_PORTS[ parsed.scheme ]
-- Preconnect (for SSL if needed)
local _,err = self:sock_connect(parsed.host, parsed.port)
if err then
return nil,err,nil
if parsed.scheme == 'wss' then
if type(ssl_params) ~= 'table' then
ssl_params = {
protocol = 'tlsv1',
options = {'all', 'no_sslv2', 'no_sslv3'},
verify = 'none',
ssl_params.mode = 'client'
self.sock = ssl.wrap(self.sock, ssl_params)
self.sock:dohandshake()
elseif parsed.scheme ~= 'ws' then
local key = generate_key()
local req = upgrade_request(parsed, key, self.protocol)
local n,err = self:sock_send(req)
if n ~= #req then
return nil,err,nil
local resp = {}
repeat
local line,err = self:sock_receive('*l')
resp[#resp+1] = line
if err then
return nil,err,nil
until line == ''
local response = tconcat(resp,'\r\n')
local headers = http_headers(response)
local expected_accept = sec_websocket_accept(key)
if headers['sec-websocket-accept'] ~= expected_accept then
local msg = 'Websocket Handshake failed: Invalid Sec-Websocket-Accept (expected %s got %s)'
return nil,msg:format(expected_accept,headers['sec-websocket-accept'] or 'nil'),headers
self.state = 'OPEN'
return true,headers['sec-websocket-protocol'],headers
local extend = function(obj)
obj.state = 'CLOSED'
obj.receive = receive
obj.send = send
obj.close = close
obj.connect = connect
return obj
local client_copas = function(timeout)
local copas = require('copas')
local self = {}
self.sock_connect = function(self,host,port)
self.sock = socket.tcp()
self.sock:settimeout(timeout or 5)
local _,err = copas.connect(self.sock,host,port)
if err and err ~= 'already connected' then
self.sock:close()
return nil,err
self.sock_send = function(self,...)
return copas.send(self.sock,...)
self.sock_receive = function(self,...)
return copas.receive(self.sock,...)
self.sock_close = function(self)
self.sock:close()
self = extend(self)
return self
local client_sync = function(timeout)
local self = {}
local _,err = self.sock:connect(host,port)
if err then
self.sock:close()
return nil,err
return self.sock:send(...)
return self.sock:receive(...)
self.sock:close()
self = extend(self)
return self
local client = function(mode, timeout)
if mode == 'copas' then
return client_copas(timeout)
return client_sync(timeout)
return {
client = client,
CONTINUATION = CONTINUATION,
TEXT = TEXT,
BINARY = BINARY,
CLOSE = CLOSE,
PING = PING,
PONG = PONG
Main changes:
if not ws then
client:connect(url)
Hi Admin,
Can I ask what the websocket.lua is meant for? What do you do with that?
refreshing old thread as i'm having troubles implementing websocket client. The problem is that client does not timeout – i.e. it runs indefinitely until it received data from the socket, and also it does not timeout if socket disconnects (for ex. when server this client connects to goes offline).
i've traced it down to websockets library, specifically to copas.receive() call which hangs there indefinitely. Is there a way to make it work? It seems this goes into the library itself, which is built-in into LM and doesn't seem to be up to date.
You can add newer copas library as a user library. It requires some extra Lua libraries which can added the same way. Just make sure to all require calls reference 'user.libname' instead of 'libname'.
Built-in copas in LM won't be upgraded to keep backward compatibility with existing scripts that rely on a certain behavior.
