hostname
Hello, is it possible to have the hostname of the lmachine by script
something like
myname= hostname
SE ECO EXPERT
hostname = io.readfile('/proc/sys/kernel/hostname'):trim()
Heart
SE ECO EXPERT
hi, how can i write a hostname by script?
io.writefile...
Try this
------------------------------------ require('uci') uci.set("system.@system[0].hostname=name63characters") uci.commit('system') --------------------------------------
What Daniel posted will work but you will have to reboot for hostname to change. You should also write to hostname file in order to change it right away:
io.writefile('/proc/sys/kernel/hostname', 'myhostname')
(14.05.2020, 07:52)Daniel. Wrote: Try this
Thank but does not work, maybe it's also me Smile
(14.05.2020, 07:55)admin Wrote: What Daniel posted will work but you will have to reboot for hostname to change. You should also write to hostname file in order to change it right away:
worked but the old name is adopted after a restart Sad
I tried it and it worked. Your browser cache?
You need to run both code pieces to set both permanent and current hostname:
hostname = 'myhostname' require('uci') uci.set("system.@system[0].hostname=" .. hostname) uci.commit('system') io.writefile('/proc/sys/kernel/hostname', hostname)
sorry it works! thanks forgot a sign...
after the restart it will be kept
