I have tried this influxdb-connection and got it to work.
I want to write several tags to influxdb and can't really figure out the best way to do this in scripts.....
Data like temperatures, Co2 and also presence objects are data I need to log i influx.
Could anyone give me a push in the right direction here.
Planning to use this with grafana.
Everything is up and running but can't figure out the most vital part:-)
28.05.2020, 16:47 (This post was last modified: 28.05.2020, 16:49 by myg.)
This code will send everything it captures to influx, then you can filter whatever you want in grafana. Create resident script with zero delay
local http = require('socket.http')
http.TIMEOUT = 5
local dt_cache = {}
function get_value(addr, datahex)
local dt = dt_cache[addr]
if(not dt) then
dt = grp.find(addr)
dt_cache[addr] = dt
return knxdatatype.decode(datahex, dt.datatype), dt
function knx_callback(event)
local addr = event.dst
local value, dt = get_value(addr, event.datahex)
send_metric('rawdata', dt.name, addr, value)
function send_metric(table, name, addr, value)
if(name == nil or name == '') then
return
name = string.gsub(name, ' ', '\\ ')
local url = 'http://IP:8086/write?db=knxdb'
local args
if(type(value) == 'boolean') then
args = string.format('%s,name=%s,addr=%s state=%s', table, name, addr, value)
-- most likely number
args = string.format('%s,name=%s,addr=%s value=%s', table, name, addr, value)
res, err = http.request(url, args)
if(err ~= 204) then
log('error sending to influx', res, err, args)
function run_loop()
local bus = require('localbus').new(1)
bus:sethandler('groupwrite', knx_callback)
local busfd = socket.fdmaskset(bus:getfd(), 'r')
while(true) do
res, fbus = socket.selectfds(10, busfd)
if(fbus) then
bus:step()
run_loop()
Modified send_metric function for the previous example. Replace IP/BUCKET/ORG/TOKEN placeholders with your parameters.
if name == nil or name == '' then
return
local url = 'http://IP:8086/api/v2/write?bucket=BUCKET&org=ORG'
local body
if type(value) == 'boolean' then
body = string.format('%s,name=%s,addr=%s state=%s', table, name, addr, value)
body = string.format('%s,name=%s,addr=%s value=%s', table, name, addr, value)
local res, code = http.request({
url = url,
method = 'POST',
body = body,
headers = {
Authorization = 'Token TOKEN'
if code ~= 204 then
log('error sending to influx', res, code, body)
14.12.2021, 13:07 (This post was last modified: 14.12.2021, 13:13 by thomasoppida.)
[attachment=2455 Wrote:admin pid='24163' dateline='1639476013']Modified send_metric function for the previous example. Replace IP/BUCKET/ORG/TOKEN placeholders with your parameters.
return
local body
url = url,
method = 'POST',
body = body,
headers = {
if code ~= 204 then
Thank you for responding Admin. I tried to put in your code in Postman just to verify that access is ok.
I can see to get response in postman I have to set Authorization to Oauth 2.0 and I get the header prefix Bearer.
Do I replace Token with Bearer instead in the script? I didn't get this to work either... Suggestions?
It should be Token not Bearer. That's what the documentation states and what worked for me. What kind of error are you getting? Have you checked that the user with this token has correct write access rights to the bucket?
Hi, I have tried the influxdb V2 script above. Get's the following response in the log for all tags (here an example writing brightness value from weather station). Any ideas?
InfluxWrite 23.12.2021 15:50:52
* arg: 1
* string: error sending to influx
* arg: 2
* string: <html>
<head><title>405 Not Allowed</title></head>
<body>
<center><h1>405 Not Allowed</h1></center>
<hr><center>nginx/1.20.2</center>
</body>
</html>
(23.12.2021, 14:59)admin Wrote: Check correctness of the url that you are sending to.
Hi.
How to set filter for addresses which are sending to influx. I would like to send just part of it (yes i know i can filter them in grafana) for example:
With this:
local range1s = buslib.encodega('1/0/0')
local range1e = buslib.encodega('2/3/15')
local range2s = buslib.encodega('4/6/7')
local range2e = buslib.encodega('5/1/15')
local id = event.dstraw
if (range1s <= id and id <= range1e) or (range2s <= id and id <= range2e) then
(07.01.2022, 12:12)admin Wrote: Replace this script part:
With this:
06.10.2022, 16:14 (This post was last modified: 06.10.2022, 16:14 by sx3.)
I'm trying out this influx integration. I get the following error in the error-log.
It managed to write about 20 adresses to influx, before failing.
It's a resident script with 0 deley.
Quote:Resident script:15: attempt to index local 'dt' (a nil value)
stack traceback:
Resident script:15: in function 'get_value'
Resident script:20: in function <Resident script:18>
Library localbus: in function ''
Library localbus: in function 'step'
Resident script:66: in function 'run_loop'
And the code (a little bit copy paste here and there from this thread)
http.TIMEOUT = 5
local dt_cache = {}
if(not dt) then
dt = grp.find(addr)
dt_cache[addr] = dt
return
local url = 'http://192.168.1.200:8086/api/v2/write?bucket=XXX&org=XXX'
local body
url = url,
method = 'POST',
body = body,
headers = {
Authorization = 'Token XXXXX'
if code ~= 204 then
function run_loop()
while(true) do
if(fbus) then
bus:step()
run_loop()
Most likely you have some group writes coming from addresses that are not present on LM.
Replace get_value/knx_callback functions with this and see if it works:
local obj = dt_cache[addr]
if obj == nil then
obj = grp.find(addr)
dt_cache[ addr ] = obj or false
if obj then
return knxdatatype.decode(datahex, obj.datatype), obj
local value, obj = get_value(addr, event.datahex)
if value ~= nil then
send_metric('rawdata', obj.name, addr, value)
07.10.2022, 14:31 (This post was last modified: 10.10.2022, 05:42 by sx3.)
Yes, I have alot of GA that is beeing used outside om LM.
Tried your code but it gives me following error
Also wonder how the string would like like if I want to transmit a modified Timestamp, and where should it be placed?
For example (strTime = os.time() + 3600)
http.TIMEOUT = 5
local dt_cache = {}
if obj == nil then
if obj then
return
local url = 'http://192.168.1.200:8086/api/v2/write?bucket=xxx&org=xxx'
local body
url = url,
method = 'POST',
body = body,
headers = {
Authorization = 'Token XXXX'
if code ~= 204 then
function run_loop()
while(true) do
if(fbus) then
bus:step()
run_loop()
