I'm practicing making widgets and when I see a widget available like the picture I can press the sun icon to open up other options. I tried a lot in the creator section and didn't know how to do it.
Can someone just help me on how to do it !
Hi the import works only the issue was in the folder structure. Attached the corrected structure.
While importing it is important that the key match the one in script, in this case it is gamma_air.
Refresh after import.
05.08.2020, 07:55 (This post was last modified: 05.08.2020, 08:10 by pouralise.)
(20.07.2020, 08:50)Daniel. Wrote: OK but you really need to know what you are doing.
(05.08.2020, 07:49)Daniel. Wrote: Hi the import works only the issue was in the folder structure. Attached the corrected structure.
Thank you let me try
How to call that widget? I didnt see it in custome widget after finish uploading. Don't see it in "Show all tab too"
