Modbus Mapping
need help a little - I can't correctly read statuses from ventilation machine.  I create mapping, but some is done not correctly:
In manual:
Current mode R/W unsigned char 0 - 10
READ ONLY:
Stanby = 0,
Away = 1,
Normal = 2,
Intensive = 3,
Boost = 4,
Kitchen = 5,
Fireplace = 6,
Override = 7,
Holiday = 8,
Air quality = 9,
Off = 10
WRITE ONLY:
Away = 1,
Normal = 2,
Intensive = 3,
Boost = 4
Mine:
      "name": "Current Mode Statuss and Change",
      "bus_datatype": "uint8",
      "datatype": "uint16",
      "type": "register",
      "address": 4,
  "writable": 1,
      "value_custom": {
        "0": "StandBy",
        "1": "Away",
        "2": "Normal",
"3": "Intensive",
"4": "Boost",
"5": "Kitchen",
"6": "Fireplace",
"7": "Override",
"8": "Holiday",
"9": "Air Quality",
"10": "Off"
Also problem to read CO2 sensor:
manual:
Air quality or humidity
(sensor 1 - B8) RO unsigned short 0 - 65535 ppm,%
Mine:
"name": "AirQuality sensor2 CO2",
"datatype": "uint8",
"type": "register",
"address": 951,
"writable": 0,
"units": "ppm",
"value_multiplier": "1"
What datatype and bus datatype should be??
Alexander
Hi Use RTU read test with int16/uint16 and paste results for both registers.
Daniel,
sorry, I not mention I use Modbus TCP mapping, and as I found test works only for RTU mode..
Alex
Try via script then
require('luamodbus') mb = luamodbus.tcp() mb:open('192.168.0.1', 502) mb:connect() mb:setslave(1) -- read from address 1000 value = mb:readregisters(1000) log(value)
(24.07.2020, 13:28)Daniel. Wrote: Try via script then
Daniel,
thank you very much, variant int16/uint16 working as needed.
Alex
