Hue Brightness feedback
#41
(31.07.2020, 07:53)Erwin van der Zwart Wrote: Hi,
I checked and line 21 is handling the response of the function getHueLights() that is located in the user.hue, so i guess you use a older version of the user lib.
Can you try to replace your user.hue with this version? A restart might be required.
Thank you, it's working nowSmile
Magnus
Hi Ervin,
since i update the user.hue to V4 i get this error message every time:
Resident script:62: attempt to perform arithmetic on a nil value stack traceback:
this is my resident script:
-- Set name (Lookup in HUE app under light configuration) and feedback adresses (don't change statevalue, brivalue and colorvalue as they are used as memoryfield) addressmapping = {   -- Name                  -- On/Off FB       -- Bright FB   -- Color FB   ['Schlafzimmer'] = {state = '10/1/27', bri = '10/1/15',  rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Laura Wand Links'] = {state = '32/1/7', bri = '32/1/9', rgb = '32/1/16', statevalue = '', brivalue = '', colorvalue = ''},   ['Laura Wand Rechts'] = {state = '32/1/8', bri = '32/1/10', rgb = '', statevalue = '', brivalue = '', colorvalue = ''},   ['Küche Led'] = {state = '32/1/11', bri = '32/1/13', rgb = '10/1/5', statevalue = '', brivalue = '', colorvalue = ''},   ['Küche indirekt'] = {state = '32/1/12', bri = '10/1/3', rgb = '32/1/14', statevalue = '', brivalue = '', colorvalue = ''},   ['Esstisch'] = {state = '10/1/157', bri = '10/1/159', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Laura Zelt'] = {state = '10/1/25', bri = 'x/x/x', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Wohnzimmer Links'] = {state = '32/1/3', bri = '32/1/5', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Wohnzimmer Rechts'] = {state = '32/1/4', bri = '32/1/6', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Kinderzimmer Links'] = {state = '32/1/17', bri = '32/1/19', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Kinderzimmer Rechts'] = {state = '32/1/18', bri = '32/1/20', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Küche Theke'] = {state = '10/1/161', bri = '10/1/163', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''} } -- Set polling interval in seconds interval = 1 -- Use logging logging = true require('user.hue') require('json') -- loop indefenitly while true do   reply = getHueLights()   mylamps = json.decode(reply)   for _, item in pairs(mylamps) do     -- Check if lamp is found by bridge otherwise it make no sense to send commands     if item.state.reachable == true then       -- On/Off       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['state']         if addr and addr ~= '' then           currentvalue = addressmapping[item.name]['statevalue']           if currentvalue ~= item.state.on then             grp.write(addr, item.state.on)             addressmapping[item.name]['statevalue'] = item.state.on             if logging == true then               log('lamp ' .. item.name .. ' state is: ' .. tostring(item.state.on))             end           end         end       end       -- Brightness       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['bri']         if addr and addr ~= '' then           -- Check if lamp is on otherwise overrule BRI value to 0           if item.state.on == false then             item.state.bri = 0           end           currentvalue = addressmapping[item.name]['brivalue']           if currentvalue ~= item.state.bri then             grp.write(addr, math.floor((tonumber(item.state.bri)/2.55) + 0.5))             addressmapping[item.name]['brivalue'] = item.state.bri             if logging == true then               log('lamp ' .. item.name .. ' brightness is: ' .. math.floor((tonumber(item.state.bri)/2.55) + 0.5) .. ' %')             end           end         end       end       -- Color       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['rgb']         if addr and addr ~= '' then           -- Check if lamp is on otherwise overrule color value to 0           if item.state.on == false then              colorvalue = 0           end           if item.state.colormode == 'xy' then             currentvalue = addressmapping[item.name]['colorvalue']             colorvalue = xy_to_rgb(item.state.xy[1],item.state.xy[2],item.state.bri)             --colorvalue = xyz_to_rgb((item.state.xy[1] * 100), (item.state.xy[2] * 100))             if currentvalue ~= colorvalue then               grp.write(addr, colorvalue)               addressmapping[item.name]['colorvalue'] = colorvalue               if logging == true then                 log('lamp ' .. item.name .. ' color is: ' .. colorvalue)               end             end           elseif item.state.colormode == 'ct' then             currentvalue = addressmapping[item.name]['colorvalue']             --colortemp = math.floor((item.state.ct / 0.0769) + 0.5)  --0.0769230769230769             colortemp = math.abs((item.state.ct - 500) / 2)             colortemp = math.floor(colortemp + 0.5)             colortemp = 80 + colortemp             if colortemp > 255 then               colortemp = 255             end             r = lmcore.inttohex(255, 1)             g = lmcore.inttohex(255, 1)             b = lmcore.inttohex(colortemp, 1)             rgb = r .. g .. b             colortemp = lmcore.hextoint(rgb,3)             if currentvalue ~= colortemp then               --colortempconverted = ct_to_rgb(colortemp)               grp.write(addr, colortemp)               addressmapping[item.name]['colorvalue'] = colortemp               if logging == true then                 log('lamp ' .. item.name .. ' color is: ' .. colortemp)               end             end           end         end       end           end     --log('manufacturername = ' .. item.manufacturername)     --log('swversion = ' .. item.swversion)     --log('type = ' .. item.type)     --log('ct = ' .. item.state.ct)     --log('reachable = ' .. item.state.reachable)     --log('alert = ' .. item.state.alert)     --log('on = ' .. item.state.on)       --log('bri = ' .. item.state.bri)     --log('colormode = ' .. item.state.colormode)     --log('hue = ' .. item.state.hue)     --log('sat = ' .. item.state.sat)     --log('effect = ' .. item.state.effect)     --log('x = ' .. item.state.xy[1])     --log('y = ' .. item.state.xy[2])     --log('uniqueid = ' .. item.uniqueid)     --log('modelid = ' .. item.modelid)     --log('name = ' .. item.name)   end     -- Delay loop     os.sleep(interval) end
line 62 is the grp.write, before i used your script in V3.
HW is an HL V1 running LM Firmware 202007 RC2.
Lars
Try this: (I added a check to be sure the device supports BR, CT or XY)
-- Set name (Lookup in HUE app under light configuration) and feedback adresses (don't change statevalue, brivalue and colorvalue as they are used as memoryfield) addressmapping = {   -- Name                  -- On/Off FB       -- Bright FB   -- Color FB   ['Schlafzimmer'] = {state = '10/1/27', bri = '10/1/15',  rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Laura Wand Links'] = {state = '32/1/7', bri = '32/1/9', rgb = '32/1/16', statevalue = '', brivalue = '', colorvalue = ''},   ['Laura Wand Rechts'] = {state = '32/1/8', bri = '32/1/10', rgb = '', statevalue = '', brivalue = '', colorvalue = ''},   ['Küche Led'] = {state = '32/1/11', bri = '32/1/13', rgb = '10/1/5', statevalue = '', brivalue = '', colorvalue = ''},   ['Küche indirekt'] = {state = '32/1/12', bri = '10/1/3', rgb = '32/1/14', statevalue = '', brivalue = '', colorvalue = ''},   ['Esstisch'] = {state = '10/1/157', bri = '10/1/159', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Laura Zelt'] = {state = '10/1/25', bri = 'x/x/x', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Wohnzimmer Links'] = {state = '32/1/3', bri = '32/1/5', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Wohnzimmer Rechts'] = {state = '32/1/4', bri = '32/1/6', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Kinderzimmer Links'] = {state = '32/1/17', bri = '32/1/19', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Kinderzimmer Rechts'] = {state = '32/1/18', bri = '32/1/20', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''},   ['Küche Theke'] = {state = '10/1/161', bri = '10/1/163', rgb = 'x/x/x', statevalue = '', brivalue = '', colorvalue = ''} } -- Set polling interval in seconds interval = 1 -- Use logging logging = false -- Load needed lib's require('user.hue') require('json') -- loop indefenitly while true do   reply = getHueLights()   mylamps = json.decode(reply)   for _, item in pairs(mylamps) do     -- Check if lamp is found by bridge otherwise it make no sense to send commands     if item.state.reachable == true then       -- On/Off       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['state']         if addr and addr ~= '' then           currentvalue = addressmapping[item.name]['statevalue']           if currentvalue ~= item.state.on then             grp.checkwrite(addr, item.state.on)             addressmapping[item.name]['statevalue'] = item.state.on             if logging == true then               log('lamp ' .. item.name .. ' state is: ' .. tostring(item.state.on))             end           end         end       end       --Brightness       if item.state.bri then         name = addressmapping[item.name]         if name then           addr = addressmapping[item.name]['bri']           if addr and addr ~= '' then             -- Check if lamp is on otherwise overrule BRI value to 0             if item.state.on == false then               item.state.bri = 0             end             currentvalue = addressmapping[item.name]['brivalue'] or 0             if currentvalue ~= item.state.bri then               grp.checkwrite(addr, math.floor((tonumber(item.state.bri)/2.55) + 0.5))               addressmapping[item.name]['brivalue'] = item.state.bri               if logging == true then                 log('lamp ' .. item.name .. ' brightness is: ' .. math.floor((tonumber(item.state.bri)/2.55) + 0.5) .. ' %')               end             end           end         end       end             --Color       if item.state.ct or item.state.xy then         name = addressmapping[item.name]         if name then           addr = addressmapping[item.name]['rgb']           if addr and addr ~= '' then             -- Check if lamp is on otherwise overrule color value to 0             if item.state.on == false then                colorvalue = 0             end             if item.state.colormode == 'xy' then               currentvalue = addressmapping[item.name]['colorvalue']               colorvalue = xy_to_rgb(item.state.xy[1],item.state.xy[2],item.state.bri)               --colorvalue = xyz_to_rgb((item.state.xy[1] * 100), (item.state.xy[2] * 100))               if currentvalue ~= colorvalue then                 grp.checkwrite(addr, colorvalue)                 addressmapping[item.name]['colorvalue'] = colorvalue                 if logging == true then                   log('lamp ' .. item.name .. ' color is: ' .. colorvalue)                 end               end             elseif item.state.colormode == 'ct' then               currentvalue = addressmapping[item.name]['colorvalue']               --colortemp = math.floor((item.state.ct / 0.0769) + 0.5)  --0.0769230769230769               colortemp = math.abs((item.state.ct - 500) / 2)               colortemp = math.floor(colortemp + 0.5)               colortemp = 80 + colortemp               if colortemp > 255 then                 colortemp = 255               end               r = lmcore.inttohex(255, 1)               g = lmcore.inttohex(255, 1)               b = lmcore.inttohex(colortemp, 1)               rgb = r .. g .. b               colortemp = lmcore.hextoint(rgb,3)               if currentvalue ~= colortemp then                 --colortempconverted = ct_to_rgb(colortemp)                 grp.checkwrite(addr, colortemp)                 addressmapping[item.name]['colorvalue'] = colortemp                 if logging == true then                   log('lamp ' .. item.name .. ' color is: ' .. colortemp)                 end               end             end           end         end       end     end   end   -- Delay loop   os.sleep(interval) end
Thank you Erwin. No more errors. Big Grin
I saw in the user.hue an Line send to Group. Have you any scripts to controll an entire Hue Group ?
At the moment i control a Group that each Light has an own event based script wich is triggerd by the same tag behind the KNX Group adress.
Yes you can do that, in the user.hue there are already 2 functions to use for group commands, getHueGroups() and sendToGroup()
First you have to get the groups by this command:
--Get all group information require('user.hue') -- get all lights from bridge result = getHueGroups() log(result)
When you know the group ID you can control it with:
require('user.hue') value = event.getvalue() group_id = 1 -- change this ID to your actual group, see getHueGroups() result if value == true then   body_msg = '{"on":true}'   sendToGroup(group_id,body_msg) else   body_msg = '{"on":false}'   sendToGroup(group_id,body_msg) end
Hi Ervin,
thank you for your help. The Script for group switching works perfect. I tried the same with brigtness but had no luck. Just change the script from lampID to GroupID didn´t work.
Do you have any scripts for controlling the Brightness, RGB an CT for Group´s with Feedback ?
Is there a chance that upcomming releases of W4K Firmware have an nativ integration of Philips HUE ?
Lars
Did you also called the function sendToGroup?
No I don’t think so, i have not seen any development in that direction, they work on speech control and new mobile app at this moment. Maybe i will start a new project to build a app for HUE this winter, but I don’t have time until November this year..
I Tried this with no effect
--Control HUE from byte object (brightness) (use as event based script) require('user.hue') value = event.getvalue()  -- 1 byte unsigned integer scale 0 - 100 group_id = 1 -- change this ID to your actual light, see getHueLights() result for lamps or use your app to resolve them setBrightness(group_id,value)
then i added a function in user.hue with also no luck.
function setBrightness(Group_id,brightness)   if brightness == 0 then       body_msg = '{"on":false}'       response = sendToGroup(group_id,body_msg)     return response   else     brightness = math.floor((brightness / 1) + 0.5)     brightness = math.floor((brightness * 2.54) + 0.5)     --HTTP request send     body_msg = '{"on":true,"bri":'..brightness..'}'     response = sendToGroup(Group_num,body_msg)     return response   end end
You have 2 mistakes in your script:
response = sendToGroup(group_id,body_msg) should be response = sendToGroup(Group_id,body_msg) and response = sendToGroup(Group_num,body_msg) should be response = sendToGroup(Group_id,body_msg)
I just tested with my latest user lib and this command and works perfect
require('user.hue') require('json') --log(json.pdecode(getHueGroups())) -- enable to check group number --setBrightnessGroup(1,100) -- Group, brightness in % setBrightnessCTGroup(1,60,2000) -- Group, brightness in %, CT in Kelvin
.lua   user.hue v5.lua (Size: 11.17 KB / Downloads: 73)
Hi Erwin,
I just configured a group and i can control the group via the group-script. However i can not get the status of this group to update.
-- Set name (Lookup in HUE app under light configuration) and feedback adresses (don't change statevalue, brivalue and colorvalue as they are used as memoryfield) addressmapping = {   -- Name                  -- On/Off FB       -- Bright FB   -- Color FB   ['Led terras'] = {state = '20/0/1', bri = '20/1/1', rgb = '20/2/1', ct = '20/3/1', statevalue = '', brivalue = '', colorvalue = ''},   ['Keuken Eiland'] = {state = '20/0/2', bri = '20/1/2', rgb = '20/2/2', statevalue = '', brivalue = '', colorvalue = ''},   ['Keuken Werkblad R'] = {state = '20/0/3', bri = '20/1/3', rgb = '20/2/3', statevalue = '', brivalue = '', colorvalue = ''},   ['Keuken Werkblad L'] = {state = '20/0/4', bri = '20/1/4', rgb = '20/2/4', statevalue = '', brivalue = '', colorvalue = ''},   ['Douche L'] = {state = '20/0/5', bri = '20/1/5', rgb = '20/2/5', statevalue = '', brivalue = '', colorvalue = ''},   ['Douche R'] = {state = '20/0/6', bri = '20/1/6', rgb = '20/2/6', statevalue = '', brivalue = '', colorvalue = ''},   ['Keuken Werkblad'] = {state = '20/0/7', bri = '20/1/7', rgb = '20/2/7', statevalue = '', brivalue = '', colorvalue = ''}, }
It's the last line in the code "Keuken Werkblad" The individual lamps "Keuken Werkblad L" & "Keuken Werkblad R" get updated in both "state", "bri" and "rgb"
Can you help me out?
Novice DIY with a HL and KNX basics trying to ...
Erwin's script uses getHueLights() which does not include groups. Try this to get info for both lights and groups together (replace the relevant script part with this):
-- loop indefenitly while true do   reply = getHueLights()   mylamps = json.decode(reply)   -- get groups start   reply = getHueGroups()   groups = json.pdecode(reply)   if type(groups) == 'table' then     for k, v in pairs(groups) do       mylamps[ k ] = v     end   end   -- get groups end   for _, item in pairs(mylamps) do
Dear Admin,
I've added these lines to the resident Hue script. Now none of the Hue lamp statusses are updated, neither the brightness nor the rgb. These worked before i added the lines. I do not get log's when switching lamps on or off. No error logs as well. I'm using the v5 user.hue library.
-- Set name (Lookup in HUE app under light configuration) and feedback adresses (don't change statevalue, brivalue and colorvalue as they are used as memoryfield) addressmapping = {   -- Name                  -- On/Off FB       -- Bright FB   -- Color FB   ['Led terras'] = {state = '20/0/1', bri = '20/1/1', rgb = '20/2/1', ct = '20/3/1', statevalue = '', brivalue = '', colorvalue = ''},   ['Keuken Eiland'] = {state = '20/0/2', bri = '20/1/2', rgb = '20/2/2', statevalue = '', brivalue = '', colorvalue = ''},   ['Keuken Werkblad R'] = {state = '20/0/3', bri = '20/1/3', rgb = '20/2/3', statevalue = '', brivalue = '', colorvalue = ''},   ['Keuken Werkblad L'] = {state = '20/0/4', bri = '20/1/4', rgb = '20/2/4', statevalue = '', brivalue = '', colorvalue = ''},   ['Douche L'] = {state = '20/0/5', bri = '20/1/5', rgb = '20/2/5', statevalue = '', brivalue = '', colorvalue = ''},   ['Douche R'] = {state = '20/0/6', bri = '20/1/6', rgb = '20/2/6', statevalue = '', brivalue = '', colorvalue = ''},   ['Keuken Werkblad'] = {state = '20/0/7', bri = '20/1/7', rgb = '20/2/7', statevalue = '', brivalue = '', colorvalue = ''}, } -- Set polling interval in seconds interval = 1 -- Use logging logging = true require('user.hue') require('json') -- loop indefenitly while true do   reply = getHueLights()   mylamps = json.decode(reply)     -- get groups start   reply = getHueGroups()   groups = json.pdecode(reply)   if type(groups) == 'table' then     for k, v in pairs(groups) do       mylamps[ k ] = v     end   end   -- get groups end     for _, item in pairs(mylamps) do     -- Check if lamp is found by bridge otherwise it make no sense to send commands     if item.state.reachable == true then       -- On/Off       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['state']         if addr and addr ~= '' then           currentvalue = addressmapping[item.name]['statevalue']           if currentvalue ~= item.state.on then             grp.update(addr, item.state.on)             addressmapping[item.name]['statevalue'] = item.state.on             if logging == true then               log('lamp ' .. item.name .. ' state is: ' .. tostring(item.state.on))             end           end         end       end       -- Brightness       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['bri']         if addr and addr ~= '' then           -- Check if lamp is on otherwise overrule BRI value to 0           if item.state.on == false then             item.state.bri = 0           end           currentvalue = addressmapping[item.name]['brivalue']           if currentvalue ~= item.state.bri then             grp.update(addr, math.floor((tonumber(item.state.bri)/2.55) + 0.5))             addressmapping[item.name]['brivalue'] = item.state.bri             if logging == true then               log('lamp ' .. item.name .. ' brightness is: ' .. math.floor((tonumber(item.state.bri)/2.55) + 0.5) .. ' %')             end           end         end       end       -- Color       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['rgb']         if addr and addr ~= '' then           -- Check if lamp is on otherwise overrule color value to 0           if item.state.on == false then              colorvalue = 0           end           if item.state.colormode == 'xy' then             currentvalue = addressmapping[item.name]['colorvalue']             colorvalue = xy_to_rgb(item.state.xy[1],item.state.xy[2],item.state.bri)             --colorvalue = xyz_to_rgb((item.state.xy[1] * 100), (item.state.xy[2] * 100))             if currentvalue ~= colorvalue then               grp.update(addr, colorvalue)               addressmapping[item.name]['colorvalue'] = colorvalue               if logging == true then                 log('lamp ' .. item.name .. ' color is: ' .. colorvalue)               end             end           elseif item.state.colormode == 'ct' then             currentvalue = addressmapping[item.name]['colorvalue']             --colortemp = math.floor((item.state.ct / 0.0769) + 0.5)  --0.0769230769230769             colortemp = math.abs((item.state.ct - 500) / 2)             colortemp = math.floor(colortemp + 0.5)             colortemp = 80 + colortemp             if colortemp > 255 then               colortemp = 255             end             r = lmcore.inttohex(255, 1)             g = lmcore.inttohex(255, 1)             b = lmcore.inttohex(colortemp, 1)             rgb = r .. g .. b             colortemp = lmcore.hextoint(rgb,3)             if currentvalue ~= colortemp then               --colortempconverted = ct_to_rgb(colortemp)               grp.update(addr, colortemp)               addressmapping[item.name]['colorvalue'] = colortemp               if logging == true then                 log('lamp ' .. item.name .. ' color is: ' .. colortemp)               end             end           end         end       end           end     --log('manufacturername = ' .. item.manufacturername)     --log('swversion = ' .. item.swversion)     --log('type = ' .. item.type)     --log('ct = ' .. item.state.ct)     --log('reachable = ' .. item.state.reachable)     --log('alert = ' .. item.state.alert)     --log('on = ' .. item.state.on)       --log('bri = ' .. item.state.bri)     --log('colormode = ' .. item.state.colormode)     --log('hue = ' .. item.state.hue)     --log('sat = ' .. item.state.sat)     --log('effect = ' .. item.state.effect)     --log('x = ' .. item.state.xy[1])     --log('y = ' .. item.state.xy[2])     --log('uniqueid = ' .. item.uniqueid)     --log('modelid = ' .. item.modelid)     --log('name = ' .. item.name)   end     -- Delay loop     os.sleep(interval) end
Kind regards
Can it be that there's a typo in the lines?
-- get groups start   reply = getHueGroups()   groups = json.pdecode(reply) -- ==>json.decode(reply) ???   if type(groups) == 'table' then     for k, v in pairs(groups) do       mylamps[ k ] = v     end   end   -- get groups end
Try this (change line 31): mylamps[ #mylamps +1 ] = v
pdecode is needed for safe deciding in case there's no reply or it is malformed.
Admin,
Individual lamp statusses are updated again, but still no update on the group status, brightness and rgb. Log's are also back now.
Add log(groups) after pdecode and post what you get in Logs tab.
this is the log:
* table: ["4"]   * table:    ["action"]     * table:      ["ct"]       * number: 153      ["alert"]       * string: select      ["on"]       * bool: true      ["bri"]       * number: 254      ["colormode"]       * string: xy      ["hue"]       * number: 41435      ["sat"]       * number: 77      ["effect"]       * string: none      ["xy"]       * table:        [1]         * number: 0.3129        [2]         * number: 0.3291    ["sensors"]     * table:    ["recycle"]     * bool: false    ["state"]     * table:      ["all_on"]       * bool: true      ["any_on"]       * bool: true    ["lights"]     * table:      [1]       * string: 4      [2]       * string: 3    ["class"]     * string: Kitchen    ["name"]     * string: Keuken Werkblad    ["type"]     * string: Room ["1"]   * table:    ["action"]     * table:      ["ct"]       * number: 331      ["alert"]       * string: none      ["on"]       * bool: false      ["bri"]       * number: 254      ["colormode"]       * string: xy      ["hue"]       * number: 58281      ["sat"]       * number: 142      ["effect"]       * string: none      ["xy"]       * table:        [1]         * number: 0.4359        [2]         * number: 0.2811    ["sensors"]     * table:    ["recycle"]     * bool: false    ["state"]     * table:      ["all_on"]       * bool: false      ["any_on"]       * bool: false    ["lights"]     * table:      [1]       * string: 1    ["class"]     * string: Terrace    ["name"]     * string: Tuin    ["type"]     * string: Room ["2"]   * table:    ["action"]     * table:      ["on"]       * bool: false      ["alert"]       * string: none    ["sensors"]     * table:    ["recycle"]     * bool: false    ["state"]     * table:      ["all_on"]       * bool: false      ["any_on"]       * bool: false    ["lights"]     * table:    ["class"]     * string: Bathroom    ["name"]     * string: Badkamer    ["type"]     * string: Room ["6"]   * table:    ["action"]     * table:      ["ct"]       * number: 343      ["alert"]       * string: select      ["on"]       * bool: false      ["bri"]       * number: 254      ["colormode"]       * string: xy      ["hue"]       * number: 8597      ["sat"]       * number: 121      ["effect"]       * string: none      ["xy"]       * table:        [1]         * number: 0.4452        [2]         * number: 0.4068    ["sensors"]     * table:    ["recycle"]     * bool: false    ["state"]     * table:      ["all_on"]       * bool: false      ["any_on"]       * bool: false    ["lights"]     * table:      [1]       * string: 5      [2]       * string: 6    ["class"]     * string: Bathroom    ["name"]     * string: Douche    ["type"]     * string: Room ["3"]   * table:    ["action"]     * table:      ["ct"]       * number: 156      ["alert"]       * string: select      ["on"]       * bool: true      ["bri"]       * number: 254      ["colormode"]       * string: ct      ["hue"]       * number: 41432      ["sat"]       * number: 75      ["effect"]       * string: none      ["xy"]       * table:        [1]         * number: 0.3146        [2]         * number: 0.3304    ["sensors"]     * table:    ["recycle"]     * bool: false    ["state"]     * table:      ["all_on"]       * bool: true      ["any_on"]       * bool: true    ["lights"]     * table:      [1]       * string: 2    ["class"]     * string: Kitchen    ["name"]     * string: Keuken Eiland    ["type"]     * string: Room
Try this:
v.state = v.action mylamps[ #mylamps +1 ] = v
There's no full state response for groups, only the last sent values.
No change. Group doesn't get updated
How do you get CT state in the resident Script ??
I tried adding , ct = x/x/x , after the RGB state valeu but nothing happens.
Try adding this to the script before -- Color:
-- color temperature       name = addressmapping[item.name]       if name and item.state.ct then         addr = addressmapping[item.name]['ct']         if addr and addr ~= '' then           newvalue = math.floor(1000000 / item.state.ct)           currentvalue = addressmapping[item.name]['ctvalue']           if currentvalue ~= newvalue then             grp.update(addr, newvalue)             addressmapping[item.name]['ctvalue'] = newvalue             if logging == true then               log('lamp ' .. item.name .. ' color temperature is: ' .. newvalue .. ' K')             end           end         end       end
