Hello I have this sample script for the definition and call of functions.
It works perfectly regardless of the order of the numbers passed to the function, it always returns the largest.
I have this other variation.
Here the problem is that if I change the order of the numbers, the function does not return the highest, it seems that it always returns the first.
What could this be due to? Is the way to call the function and pass it the arguments wrong?
a greeting
function max(numero1, numero2)
if (numero1 > numero2) then
resultado = numero1;
resultado = numero2;
return resultado; --
log('El valor máximo de la comparación de dos valores es',max(4,10))
log('El valor máximo de la comparación de dos valores es',max(6,5))I have this other variation.
max = 4, 10
log('El valor máximo de la comparación de dos valores es', max)
return(resultado)
endHere the problem is that if I change the order of the numbers, the function does not return the highest, it seems that it always returns the first.
a greeting
