03.08.2020, 20:12
(This post was last modified: 03.08.2020, 20:17 by Carlos Padilla.)
Good companion. I hope they are excellent. My question is this. It is possible to create a table within another table as you will see in the image that I attach. I want to create a parent table that will be "climate profiles" and within this, the user can create create different tables such as "comfort" with different settings as if the user wants to turn on the air, what is the temperature you want configure, fan mode etc. The idea is that I can have several tables such as Climate profiles, Occupation profiles, curtain profiles, etc., but that the client can add internal tables and configure what they want. This information should ideally be stored in the storage. Currently I have been able to store tables but independent, but not tables within tables as seen in the image. Thank you for your cooperation.
