Control KNX Dimmer lights with Alexa App
When we configure a knx dimmable light in the alexa app in LM:
Should we create two devices: in the first device we configure a "power State" skill with the 1-bit KNX objects and in the second device we configure a "percentage" skill with the 1-byte objects?
Or, do we create a single device, with two skills, one for 1-bit objects in the power state skill and the other skill for 1-byte objects?
Thank you.
One device and as many skills the device support.
(08.09.2020, 13:17)Daniel. Wrote: One device and as many skills the device support.
Thanks Daniel, in the case of a KNX dimmabe light, what skill should we use: percentage or brightness?
I don't know what the difference is.
They both are the same, the only difference is later label in alexa app on mobile if you use it.
(08.09.2020, 14:25)Daniel. Wrote: They both are the same, the only difference is later label in alexa app on mobile if you use it.
Okay,
Thanks Daniel.
