16.08.2016, 16:29
Hi!
I'm in the process of setting up a BACnet server with LM. The problem is the client device can't accept the names generated by LM.
The object name is generated like this
My client need a address defined [127001]Temperatura_sobe_A138, but the generated name has space in the middle, and throws an error.
Any way to set the format by myself? Or disable the address part?
I'm using LM ver. 20150917, bacnet 0.6.0-12
2 (AV) 2048 Temperatura_sobe_A138 (1.0.0) 23.1
