20.10.2020, 21:33
¿How can I get the current user's name that was logged in the LM?
Thanks by yor help.
Thanks by yor help.
Get Current user logged
20.10.2020, 21:33
¿How can I get the current user's name that was logged in the LM? Thanks by yor help.
21.10.2020, 07:10
In newer firmwares you can access Globals.user variable in custom JavaScript. For event scripts you can check event.meta field, but it's only set when object value is changed via UI/Visualization.
21.10.2020, 17:17
(21.10.2020, 07:10)admin Wrote: In newer firmwares you can access Globals.user variable in custom JavaScript. For event scripts you can check event.meta field, but it's only set when object value is changed via UI/Visualization. I've found that Globals.user is not available from Custom Javascript when Schedulers opened. Is this intentionally?
Done is better than perfect
