alert type
Hello
I was doing some tests to check if it was possible in the alert manager to have 2 types of alerts, one with acoustic "ALARM" and one without "WARNING" maybe in a different color, so that I can differentiate the messages generated by scripts, or if you can suggest me a way to be able to see both logs in visu.
thank you so much
You can store other events separately. See this example: https://forum.logicmachine.net/showthrea...26#pid1726
(23.10.2020, 12:38)admin Wrote: You can store other events separately. See this example: https://forum.logicmachine.net/showthrea...26#pid1726
Perfect I have make all and run , if i wan't change font dimension and color is possible apply a css style in this page ?
Add style tag before closing head tag. You can add any CSS inside of the style tag.
<style> h3 { color: red; } p { font-weight: bold; } </style> </head>
(23.10.2020, 14:49)admin Wrote: Add style tag before closing head tag. You can add any CSS inside of the style tag.
Tank's for all
but now I see the day in log file is English , nut i have set all in italian language , is possible have the day in Italian ?
Change eventlog function to replace day names. Keep in mind that this will only work for newly events after the function has been modified.
12345678910111213141516171819
function eventlog(text)   local max = 1000 -- max number of entries   -- add formatted date   local date = os.date('%a %d/%m/%Y %T ')   date = date:gsub('%a+', {     Mon = 'lun.',     Tue = 'mar.',     Wed = 'mer.',     Thu = 'gio.',     Fri = 'ven.',     Sat = 'sab.',     Sun = 'dom.',   })   storage.exec('lpush', 'eventlog', date .. text)   storage.exec('ltrim', 'eventlog', 0, max - 1) end
