NTP Server
I have a project that will be using multiple LM's. Is it possible to select 1 LM as the time master and configure it as a NTP Server to server the other LM's? The LM's will be on an isolated network with no internet access. I had a look at the settings but was not sure if this is possible.
The Local server status is the NTP server you asking for. Enable it and in the other LMs put IP of the one with server enabled.
Keep in mind that you still need an accurate clock source. One solution is a GPS receiver with USB or RS232 interface if it's possible to get GPS coverage in your installation.
Thanks the the replies, ill give the local server status a try, and look at installing a device to provide accurate time to the master LM
Hallo,
It's possible create a script for read the time from a ntp server  when "wiser" it's restarted?
Best regards
Fabio Rusconi
You don’t need a script for that, when the NTP is enabled under the system settings it should sync time automatically, you need to be sure the controller has access to the internet and port 123 is not blocked by a firewall.
Thank you.
Best regards
Fabio
(19.12.2020, 06:03)Erwin van der Zwart Wrote: You don’t need a script for that, when the NTP is enabled under the system settings it should sync time automatically, you need to be sure the controller has access to the internet and port 123 is not blocked by a firewall.
Is the same on LM5 where find  function to enable NTP?
Tank's
System config > Services > NTP client/server. It's enabled by default, but requires valid network gateway and DNS settings to work.
