RGB relative dimming from KNX
Hi there. I'm trying to relative dimming, from a physical KNX button, a RGB LED strip connected to a DALI controller (https://www.dalcnet.com/en/DALI/15576-DLX1224-4CV-DALI). I'm using an ABB DALI-KNX gateway to control it (https://new.abb.com/products/2CDG110273R...-fold-mdrc).
Every colour is in 1 byte KNX object (R 1byte - G 1byte - B 1byte). As they are in separate channels, I don't know how to dimmer an specific colour (from LM visu is simple, but I can't find the way to do that from a KNX 4 bit object).
I have started running this script https://forum.logicmachine.net/showthrea...27#pid8027 but I'm stuck in looking for the next step.
Can you help me, please? Thanks in advance!  Rolleyes
Pure conversion of this script in to dimming of 3 objects is this but I'm not sure if this is what you need. Most likely you would have to calculate saturation.
addressbyteoutput1 = '32/1/1' addressbyteoutput2 = '32/1/2' addressbyteoutput3 = '32/1/3' stepsize = 10 value = event.getvalue() current1 = grp.getvalue(addressbyteoutput1) current2 = grp.getvalue(addressbyteoutput2) current3 = grp.getvalue(addressbyteoutput3) if value < 8 and value ~= 0 then   log('down',value)   if current1 <= stepsize then     output = 0     if current1 ~= output then       grp.write(addressbyteoutput1, output)        end   else     output = current1 - stepsize     if current1 ~= output then       grp.write(addressbyteoutput1, output)     end   end if current2 <= stepsize then     output = 0     if current2 ~= output then       grp.write(addressbyteoutput2, output)        end   else     output = current2 - stepsize     if current2 ~= output then       grp.write(addressbyteoutput2, output)     end   end  if current3 <= stepsize then     output = 0     if current3 ~= output then       grp.write(addressbyteoutput3, output)        end   else     output = current3 - stepsize     if current3 ~= output then       grp.write(addressbyteoutput3, output)     end   end      elseif value > 8 then   log('up',value)   if current1 >= (100 - stepsize) then     output = 100     if current1 ~= output then       grp.write(addressbyteoutput1, output)     end   else     output = current1 + stepsize     if current1 ~= output then       grp.write(addressbyteoutput1, output)     end   end     if current2 >= (100 - stepsize) then     output = 100     if current2 ~= output then       grp.write(addressbyteoutput2, output)     end   else     output = current2 + stepsize     if current2 ~= output then       grp.write(addressbyteoutput2, output)     end   end     if current3 >= (100 - stepsize) then     output = 100     if current3 ~= output then       grp.write(addressbyteoutput3, output)     end   else     output = current3 + stepsize     if current3 ~= output then       grp.write(addressbyteoutput3, output)     end   end end
(02.11.2020, 14:57)Daniel. Wrote: Pure conversion of this script in to dimming of 3 objects is this but I'm not sure if this is what you need. Most likely you would have to calculate saturation.
Thanks for the quick answer. That would work, but like dimming 3 independent lights.
I think the theorical way should be, first, to convert those 3 1byte objects in a 3byte RGB value (232.600). After that, to "dim" that value and, finally, go the other way round.
The problem is I can't achieve that  Undecided .
No one? How is this supposed to be done? Perhaps I am not approaching the problem correctly...  Sad
To dim a color your need to convert RGB to HSV, change V up/down and then convert back to RGB.
Here are the functions that you can use.
function rgbtohsv(r, g, b)   local max, min, d, h, s, v   max = math.max(r, g, b)   min = math.min(r, g, b)   d = max - min   s = max == 0 and 0 or (d / max)   v = max / 255   if max == min then     h = 0   elseif max == r then     h = (g - b) + d * (g < b and 6 or 0)     h = h / (6 * d)   elseif max == g then     h = (b - r) + d * 2     h = h / (6 * d)   elseif max == b then     h = (r - g) + d * 4     h = h / (6 * d)   end   return h, s, v end function hsvtorgb(h, s, v)   local r, g, b, i, f, p, q, t, z   i = math.floor(h * 6)   f = h * 6 - i   p = v * (1 - s)   q = v * (1 - f * s)   t = v * (1 - (1 - f) * s)   z = i % 6   if z == 0 then     r = v     g = t     b = p   elseif z == 1 then     r = q     g = v     b = p   elseif z == 2 then     r = p     g = v     b = t   elseif z == 3 then     r = p     g = q     b = v   elseif z == 4 then     r = t     g = p     b = v   elseif z == 5 then     r = v     g = p     b = q   end   r = math.round(r * 255)   g = math.round(g * 255)   b = math.round(b * 255)   return r, g, b end function rgbstep(r, g, b, up, step)   local h, s, v = rgbtohsv(r, g, b)   local v2 = up and math.min(1, v + step) or math.max(0, v - step)     if v == v2 then     return   end   return hsvtorgb(h, s, v2) end
rgbstep(r, g, b, up, step) can perform up/down step of current RGB value.
arguments:
  • r, g, b - color components in 0..255 range
  • up - true = step up / false = step down
  • step - step size, V range is 0..1 so the step should be something like 0.1 or 0.05 depending on how many total steps you want
rgbstep will return new RGB values but it might also return nil when further step is not possible.
-- values from split RGB value r = 127 g = 255 b = 10 -- step down up = false -- maximum 20 steps between min and max step = 0.05 r, g, b = rgbstep(r, g, b, up, step) if r then   -- write new values else   -- stop dimming end
(04.11.2020, 07:48)admin Wrote: To dim a color your need to convert RGB to HSV, change V up/down and then convert back to RGB.
arguments:
Thank you very much! So my only doubt is which group addresses I need to define  Blush
I'm so sorry, but I don't know how to combine that script with the objects I own. I have only three 1 byte KNX groups (R, G and B) in scale format (0-100%). Could someone help me in the next step? Thanks in advance!  Confused
Use this event script for 4-bit object. Change R/G/B addresses as needed and modify step and delay to change the dimming speed and smoothness.
raddr = '32/1/1' -- red value address gaddr = '32/1/2' -- green value address baddr = '32/1/3' -- blue value address step = 0.05 -- step side delay = 0.3 -- delay between steps value = event.getvalue() up = bit.band(value, 0x08) == 0x08 stop = bit.band(value, 0x07) == 0 if stop then   return   end -- get value and convert from 0..100 to 0..255 r = grp.getvalue(raddr) * 2.55 g = grp.getvalue(gaddr) * 2.55 b = grp.getvalue(baddr) * 2.55 function rgbtohsv(r, g, b)   local max, min, d, h, s, v   max = math.max(r, g, b)   min = math.min(r, g, b)   d = max - min   s = max == 0 and 0 or (d / max)   v = max / 255   if max == min then     h = 0   elseif max == r then     h = (g - b) + d * (g < b and 6 or 0)     h = h / (6 * d)   elseif max == g then     h = (b - r) + d * 2     h = h / (6 * d)   elseif max == b then     h = (r - g) + d * 4     h = h / (6 * d)   end   return h, s, v end function hsvtorgb(h, s, v)   local r, g, b, i, f, p, q, t, z   i = math.floor(h * 6)   f = h * 6 - i   p = v * (1 - s)   q = v * (1 - f * s)   t = v * (1 - (1 - f) * s)   z = i % 6   if z == 0 then     r = v     g = t     b = p   elseif z == 1 then     r = q     g = v     b = p   elseif z == 2 then     r = p     g = v     b = t   elseif z == 3 then     r = p     g = q     b = v   elseif z == 4 then     r = t     g = p     b = v   elseif z == 5 then     r = v     g = p     b = q   end   r = math.round(r * 255)   g = math.round(g * 255)   b = math.round(b * 255)   return r, g, b end function rgbstep(r, g, b, up, step)   local h, s, v = rgbtohsv(r, g, b)   local v2 = up and math.min(1, v + step) or math.max(0, v - step)      if v == v2 then     return   end   return hsvtorgb(h, s, v2) end while true do   r, g, b = rgbstep(r, g, b, up, step)   if r then     grp.write(raddr, r, dt.uint8)     grp.write(gaddr, g, dt.uint8)     grp.write(baddr, b, dt.uint8)   else     break   end   os.sleep(delay)   newvalue = grp.getvalue(event.dst)   if value ~= newvalue then     break   end end
(09.11.2020, 08:56)admin Wrote: Use this event script for 4-bit object. Change R/G/B addresses as needed and modify step and delay to change the dimming speed and smoothness.
Awesome! Thank you very much!!
