Logic Machine Cloud App
Hi everybody,
I've a problem with the user in the Logic Machine Cloud App.
I created an account in the cloud, I 've configured the app on 3 android phone enabled push notification, but only one of those 3 devices appears in the list of the devices inside the app Cloud Config.
what am I wrong?
Best regards Cristian
It is important for the cloud app to be install and running on LM before you enable push notifications on your mobile. Do as fallow:
1. Make sure your mobile is on the same network as LM.
2. Edit or delete the LM in the app and disable push notifications and save.
3. Edit again LM in app and enable push notification and save.
4. Refresh browser and check if your mobile is in the cloud app.
(16.11.2020, 08:32)Daniel. Wrote: It is important for the cloud app to be install and running on LM before you enable push notifications on your mobile. Do as fallow:
Thanks Daniel as always. When I came back to the plant I will try and I will let you know.
Om in this way it works. Best regards
is it possible add new device into push notification app only from cloud connection? I have problem to came on plant for add new device.
thanks
No you must be locally with the mobile connected on same network as LM.
