Trends visualization issue
Hi, it's a while I have problems to visualize trends on a wiser Schneiders:
I checked every single trends and memory usage is really low... it was working until a week ago...  so what could be the reason?
Peppe
Did you try rebooting?
many times...
is it possible if the object of the trend had a datatype change like i.e. from 09. 2 byte floating poit to 09.001 temperature ?
Send your backup via PM
I don't know how to attach it to the PM.... I don't see the relative button.
use wetransfer.com or similar. You cant attach it as file here.
I have the same issue to a customer !
First time  !
Try to clear cache...
It was a 6 month project old.
I update from 2.3 to 2.5.1 firmware and add new trend (and created category for the trend)
Here the PS:
Quote:* string:  PID USER      VSZ STAT COMMAND
    1 root      1060 S    /sbin/init
  693 root      1080 S    /sbin/syslogd -C16
  695 root      1060 S    /sbin/klogd
  697 root      860 S    /sbin/hotplug2 --override --persistent --set-rules-f
  885 root      1060 S    /sbin/watchdog -t 5 /dev/watchdog
  956 root      692 S    /usr/sbin/gpiod -l /lib/restore/defaults.sh -d /lib/
  967 root      1256 S    dropbear -p 22 -K 300
  971 root      1064 S    /usr/sbin/ntpd -n -p pool.ntp.org -p 1.schneider.poo
  982 root      3272 S<  /usr/bin/eibd -e 1.1.251 -q 100 -F n,n,n,n,0,0 tpuar
  988 root      2780 S    /usr/sbin/redis-server /etc/redis.conf
1041 root      2444 S    lua /lib/genohm-scada/core/scenes.lua
1042 root      1316 S    lua /lib/genohm-scada/core/ipblocker.lua
1044 root      2768 S    lua /lib/genohm-scada/core/groupmonitor.lua
1050 root      2944 S    lua /lib/genohm-scada/plugins/modbus/daemon.lua 0
1064 root      1872 S    lua /lib/apps/daemon.lua presence-simulation /home/a
1075 root      4196 S    nginx: master process nginx -c /tmp/nginx.conf
1077 root      8740 S    nginx: worker process
1083 root      1064 S    /usr/sbin/crond -l 20 -c /etc/crontabs
1089 root      1324 S    /usr/bin/dbus-daemon --system
1120 root      3352 S    openvpn --daemon --config /etc/openvpn/client.conf -
1187 root      1708 S    lua /lib/apps/daemon.lua processes /home/apps/store/
1246 root      4368 S    lua /lib/apps/daemon.lua sonos /home/apps/store/daem
2708 root      4696 S    lua /lib/genohm-scada/core/scripting-resident.lua 88
2897 root      1060 R    ps
SE ECO EXPERT
This happens when the trend storage file is missing probably due to a power loss during write operation. The only thing that can be done is deleting the trend that does not load and creating it again.
ok, so if I see in the backup a trend file missing, this is the one ?
Or I jsut delete trend until I found ...
Should be great to auto create the file ...
SE ECO EXPERT
(02.12.2020, 15:45)domotiqa Wrote: ok, so if I see in the backup a trend file missing, this is the one ?
I found a shortway to restore all the trends: you just need an old backup in which trends are still working and then using 7-zip, overwrite the trends directory of the present time backup. You can also verify the integrity of file with 7-zip. Then restore the updated backup file and... that's it!
What you say? have I a cygar?  Big Grin Cool
Automatic creation if the trend file is missing has already been implemented recently.
You can use 7-Zip to modify the backup file, you can also replace only the missing files not the whole directory so existing newer data is not lost.
Yes, you are right... replacing the whole directory is the shortest way if you want to restart all trends at same date.
