11.12.2020, 19:10 (This post was last modified: 11.12.2020, 19:10 by tomnord.)
Hello. So, I've been testing with zigbee and the dongle recomended from ALI, with EmbededSystems hex-file loaded.
can't seem to get this to work. does not report any devices. Also outputs some errors.
Got abit further today. managed to integrate a HUE strip. but only as standard dimmable, not rgb.. hope there wil be the opertunity to make custom profiles for equipment.
We'll update the app with Hue LightStrip plus profile soon. Can you check one thing if possible? Use "set value" option in ZigBee app try setting value to 1. Does the strip turn off at this value? What happens with value 2?
(16.12.2020, 12:17)admin Wrote: We'll update the app with Hue LightStrip plus profile soon. Can you check one thing if possible? Use "set value" option in ZigBee app try setting value to 1. Does the strip turn off at this value? What happens with value 2?
1 is of. 2 there is a minimal glare in white.
Scale goes to 255.
(21.12.2020, 07:07)admin Wrote: Which LM hardware and firmware version do you have? The easiest way for remote access is to update firmware to a beta version and use ZeroTier.
You could send me a PM with details.
I'm having some stability issues with the USB. It seems to shut down once in a while. Seen that before?
The issues with USB might be because you have an older CPU (i.MX28). ZeroTier is not supported on older firmware so maybe you can forward ports 22 and 80 to your LM?
Hello, I've connected a IKEA wallplug but it's not recognised by my LM. As I understand, IKEA uses zigbee light link. Could this be implemented you think?
