Updating multiple group adresses
I would like when i receive a value in one group address to be able use this value and send it to other group addresses.
Like for example adress 1/1/1 sends value then i am able to update group 1/1/2 and 1/1/3 with the same value.
Anyone have an idea how to achive this?
Attach an event script to 1/1/1. Make sure that all objects have the same datatype and check that no loops are produced by these scripts.
value = event.getvalue() grp.write('1/1/2', value) grp.write('1/1/3', value)
This works great. But now client want delay in between the telegrams. Could it work to put a os.sleep function between.
Function i want is. Main telegram goes out. Then he want that second group adress gets the value and sends it with a delay og 3 seconds and then the last one with a delay of 10 sec after the main group sends its telegram.
Could this work?
os.sleep(3)
os.sleep(10)
The delay should be before grp.write
(10.12.2020, 06:27)admin Wrote: Attach an event script to 1/1/1. Make sure that all objects have the same datatype and check that no loops are produced by these scripts.
(23.12.2020, 10:37)Daniel. Wrote: The delay should be before grp.write
Thanks alot.
