JS/CSS style.transition
Hi all,
in this JS, I manage CSS attributes of an image, but "transition" doesn't work : is there any reason ?
Thank's in advance for your help.
12345678910111213
$(function(){   if (typeof grp != 'undefined') {     grp.listen('0/0/2', function(object, state) {       var value = object.value;       if (value == 10) {     var elem = document.getElementsByClassName('testVR');     elem[0].style.transition = 'height 2s linear 1s';     elem[0].style.height     = '100px';     elem[0].style.overflow   = 'hidden';                }       },true);   } });
Can you explain what are you trying to do? It's better to define transition in Custom CSS and change only the required properties from JS.
it's about creating a graphic animation of a rolling shutter that opens and closes...
If you have it easier with CSS and changes of properties with JS, I'm interested!
I tested olso :
CSS :
.testVR {
2nd WAY for transition attribute in JS :
elem[0].style.setProperty("transition", "height 2s linear 0s");
But they doesn't work any more.
Working example: additional class is blinds, status object is 32/1/1, data type is 0..100% scale so the height range is from 10px to 210px.
CSS:
.blinds {   overflow: hidden;   transition: height 2s linear; }
JavaScript:
$(function() {   grp.listen('32/1/1', function(obj) {     $('.blinds').height(10 + obj.value * 2);   }); });
