Open LM4 device
OK, so I found out I have a read-only SD card (actually two of them).
Now I've had this before and replaced it then, but I completely forgot how I physically changed it Blush
Do I have to remove the device from the DIN rail? How do I open the device? I can find nothing in the manual on this subject and I don't want to break things...
TIA.
You need to power it down and take it of the panel. Remove the bottom part and then the PCB. You will find the card there.
(28.12.2020, 12:32)Daniel. Wrote: You need to power it down and take it of the panel.  Remove the bottom part and then the PCB. You will find the card there.
OK thanks.
