Bacnet- Spacelynk
Hallo,
ich finde über das Bacnet app keine Geräte. Übe die software Yabe finde ich alles.
Please post in English next time. Make sure that you have BACnet server disabled when running the client application.
the server is deactivated. if I hang a wide spacelynk in as a server, I can also find it in the client. Only the two other Bacnet devices are not. But in the software Yabe I find all devices.
How many objects does your bacnet server has?
Try running this script, this is manual scan.
res = io.readproc('bacwi')
log(res)
There are 10 objects per Bacnet server. I test the script maker.
the devices are found via the script
bacnet 03.02.2021 19:53:21
* string: 100 192.168.188.120
4194303 192.168.188.120
2 192.168.188.172
192.168.188.39: Wiser for Knx Bacnet Client script executed
192.168.188.120: Spacylink Bacnet Server
192.168.188.172: Deos Ventilation unit
192.168.188.173: Deos Ventilation unit currently not in the network
