24.01.2021, 13:20
Hallo,
ich finde über das Bacnet app keine Geräte. Übe die software Yabe finde ich alles.
Bacnet- Spacelynk
24.01.2021, 13:20
Hallo,
25.01.2021, 08:25
Please post in English next time. Make sure that you have BACnet server disabled when running the client application.
02.02.2021, 22:31
the server is deactivated. if I hang a wide spacelynk in as a server, I can also find it in the client. Only the two other Bacnet devices are not. But in the software Yabe I find all devices.
03.02.2021, 08:24
How many objects does your bacnet server has?
03.02.2021, 10:12
Try running this script, this is manual scan.
Code: res = io.readproc('bacwi')
log(res)
There are 10 objects per Bacnet server. I test the script maker.
the devices are found via the script bacnet 03.02.2021 19:53:21 * string: 100 192.168.188.120 4194303 192.168.188.120 2 192.168.188.172 192.168.188.39: Wiser for Knx Bacnet Client script executed 192.168.188.120: Spacylink Bacnet Server 192.168.188.172: Deos Ventilation unit 192.168.188.173: Deos Ventilation unit currently not in the network |
